El Camino Central :: View topic - Stripped sway-bar bushing bolt/hole
hawaii1984
Necoa #: 11592
PostPosted: Tue Oct 14, 2008 4:24 pm    Post subject: Stripped sway-bar bushing bolt/hole Reply with quote
I have one sway-bar bushing bolt that has a stripped hole. What's the size of the stock bolt and anyone have a fix/solution for this dilemma. I'm assuming a tap & dye set is in my near future....
Help..
Scott
PostPosted: Tue Oct 14, 2008 5:18 pm    Post subject: Reply with quote
If you can fit your fingers in the frame, run a longer bolt with a nylock nut and your good to go.
hawaii1984
Necoa #: 11592
PostPosted: Wed Oct 15, 2008 12:17 pm    Post subject: Can't fit fingers.. Reply with quote
Unfortunately I can't fit my fingers in there to thread a nut on. Do I have any other options?
PostPosted: Wed Oct 15, 2008 12:44 pm    Post subject: Re: Stripped sway-bar bushing bolt/hole Reply with quote
I think you answered your own question.
hawaii1984
Necoa #: 11592
PostPosted: Wed Oct 15, 2008 1:03 pm    Post subject: Re: Stripped sway-bar bushing bolt/hole Reply with quote
[/quote]I think you answered your own question.[/quote]
I was afraid of that Confused
hawaii1984
Necoa #: 11592
Harald K
Director Region 13
Director Region 13
Necoa #: 824
PostPosted: Wed Oct 15, 2008 1:30 pm    Post subject: Reply with quote
Just running a tap into the hole is probably not going to solve the problem. You will probably need to go to a larger diameter bolt but keep in mind the head will need to be small enough to fit next to the sway bar mount bracket. Depending on how badly the hole is stripped you might need to weld some material into the hole drill it out and retap the hole. There are self taping bolts that you can also use these have a bit more taper so they can grip better as they cut their own threads. The problem is that the frame is made from rather mild steel and these self taped holes do strip pretty easily. Good luck. Harald K
PostPosted: Wed Oct 15, 2008 1:56 pm    Post subject: Reply with quote
Harbor Freight (if your near one) has a decent cheap tap and die set that's ok for home use, but not if your a professional machinist. http://search.harborfreight.com/cpisearch/web/search.do?keyword=tap+and+die+set&Submit=Go I bought the 60 piece set...can't complain...it works for my needs
PostPosted: Wed Oct 15, 2008 2:01 pm    Post subject: Reply with quote
OOPS just realized your in Hawaii...no Harbor Freight there...looks like a trip to Sears is in your near future.
texaselky
Necoa #: 10419
PostPosted: Wed Oct 15, 2008 3:51 pm    Post subject: Reply with quote
I had the same thing happen on a Trans Am project a few years ago. I went to the local fastener supplier and bought a Rivnut. It comes with a bolt and special washer, you push it through the hole then tighten down the bolt. It will compress like a rivet but has threads on the inside, then just remove the bolt and bolt the sway bar on>> really easy and cost around $10.
1984 El Camino
Kyle, Texas
PostPosted: Wed Oct 15, 2008 4:43 pm    Post subject: Reply with quote
Can you fit a nut in a box end wrench and slid it in the frame far enough to get the bolt started? You could tape the nut to the wrench if you had to.
hawaii1984
Necoa #: 11592
PostPosted: Mon Oct 20, 2008 11:30 am    Post subject: still stumped w/stripped hole Reply with quote
Unfortunately the drivers side has no access holes to run a wrench in. The pass side has a perfect large hole for that, but wrong side for my dilemma.
Was wondering if anyone else has any other suggestions. Perhaps something along the lines of say a heli-coil type repair like I once had done on my cylinder heads for my intake manifold.
Thanks!!
hawaii1984
Necoa #: 11592
PostPosted: Mon Oct 20, 2008 11:46 am    Post subject: self threading bolt Reply with quote
Is there a self threading bolt with the same small head to clear the bushing bracket available? I'm going to try the local nut & bolt shop here, but I'd still like any input..
Thanks!
PostPosted: Mon Oct 20, 2008 1:05 pm    Post subject: Reply with quote
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=98522 I know you don't have a Harbor Freight in Hawaii, this kit probably doesn't have the size you need anyway...I posted more as information on what's available to you to make a repair...however if it was me I would just tap the hole for the next larger size bolt and be done with it. Any decent hardware store should have everything you need. If you don't want to buy a whole tap and die set just get a single tap the size you need and the handle...Sears has those if your local hardware doesn't. Use at least a Grade 8 bolt. I would tap all four holes so they're the same size. Also if the head of the bolt interferes with the bracket, a few small diameter washers over the bolt should solve this problem, just make sure you use a long enough bolt to grab all the threads.
PaPa Johns 77
Necoa #: 6188
PostPosted: Mon Oct 20, 2008 4:26 pm    Post subject: Reply with quote
I bought a cheap set from Wally World. Served it's pupose and got enough use out of it to more than make up for the cost! Cool
"Still Just Truck'in"
"Johnny"
Bradley, Illinois
Page Generation: 0.363 Seconds
