El Camino Central :: View topic - Starter need replacing?
highwaysignpost
Necoa #: 1571
PostPosted: Fri Feb 20, 2004 2:00 pm    Post subject: Starter need replacing? Reply with quote
My understanding is that when the starter goes, you get very little warning.
I stopped at the bank on my way home from work and when I got back in and turned the key, my Diablo attempted to turn over for about 1/2 a second and then tanked. Radio and lights still worked so I figure it's the starter. Does this sound about right? If so it'll be the first one I've changed so any hints and tips would be appreciated. anything else I should check first? It's an 81 with stock 305.
Thanks in advanced.
Proud Diablo and not that Lamborghini kind Wink
spoonplugger
Necoa #: 1271
PostPosted: Sat Feb 21, 2004 12:41 am    Post subject: Reply with quote
In my experience, the starter USUALLY DOES NOT FAIL WITHOUT SOME WARNING. The only exception is when the electric motor brushes suddenly fail because of excessive wear. When brushes suddenly fail without warning, you can easily test this condition. Simply take an axe or heavy sledge hammer and hit the starter a couple of hard licks from underneath the car while someone is turning the ignition key to "start". Sounds crazy, but I have never seen it fail. I learned this trick from a tow truck driver.
But usually, when starters begin to fail, they will give you prior warning. They will sporatically act up. They will sometimes turn slowly (especially with a hot engine) or will sometimes make a grinding noise when the starter drive begins to weaken, or it can become very loud during starting operations. Most likely though, you have a battery failing or bad electrical connections at the battery, starter or ground. Be sure to check the electricals first. It's a heck of a lot easier and cheaper than replacing the starter.
Good luck.
86 caballero, 350 cid, TH350C
a73elkyss
Tech Extraordinaire
Tech Extraordinaire
Necoa #: 768
Year: 1973
PostPosted: Sat Feb 21, 2004 9:47 am    Post subject: Reply with quote
I would agree with spoonplugger. Most likely a poor connection somewhere or the battery. One thing I found on mine was that the negative cable from the battery went to the alternator bracket. I had the same problem you described and the end result was to take the negative cable from the battery and attach it to the engine block.
Just my 2 cents.......
Watch for the 6th gen Elco's
highwaysignpost
Necoa #: 1571
PostPosted: Sat Feb 21, 2004 10:09 am    Post subject: Reply with quote
thanks, I had the tow truck guy do the same thing and nothing happened. must be a universal tow truck thing. I'll check my connections Very Happy
highwaysignpost
Necoa #: 1571
PostPosted: Sat Feb 21, 2004 5:44 pm    Post subject: Reply with quote
Thanks Spoon and thanks 72. turns out it was a bad ground connection. You guys saved me a headache. there's not a lot of room around there and I'm not looking forward to the day that the starter does go.
thanks again Happy
a73elkyss
Tech Extraordinaire
Tech Extraordinaire
Necoa #: 768
Year: 1973
PostPosted: Sat Feb 21, 2004 5:57 pm    Post subject: Reply with quote
Glad you found the problem. I hate to admit it, but I changed a battery and the starter before I found the bad ground. I learned the hard way.
spoonplugger
Necoa #: 1271
PostPosted: Sat Feb 21, 2004 10:06 pm    Post subject: Reply with quote
Glad you found the problem without pulling the starter. This forum is worth its weight in gold!
Tommy
Director Region 5
Director Region 5
PostPosted: Sun Feb 22, 2004 2:49 pm    Post subject: Reply with quote
I changed my ground to the blocka few years ago, it does make a difference. There is a bolt hole just above the fuel pump that works great.
