El Camino Central :: View topic - springs
springs
Steve84Ec
Necoa #: 1529
PostPosted: Fri Jan 02, 2004 4:26 pm    Post subject: springs Reply with quote
Okay, after a bit of looking around, I'm pretty sure i need to get coil springs. I was wondering if anyone knows of where to buy a good set thats not too extremely expensive, and won't lower the car any. I would like to stick with the stock height, i just like the look of it more. Thanks for any responses Happy
1984 El camino, V8 with wheels spinning in the back, thats the only way to do it
View user's profile Send private message Send e-mail Visit poster's website AIM Address
Camino80
Necoa #: 931
PostPosted: Fri Jan 02, 2004 5:53 pm    Post subject: Reply with quote
I posted above about shocks and springs etc. above from PST. When the springs were installed the car sat high. It took a while for it to settle to normal height. Just to let you know what to expect. Cool
1982 SS
Necoa #: 1917
PostPosted: Sat Jan 03, 2004 11:11 pm    Post subject: Reply with quote
I Got some generic NAPA/Balkamp pieces, KYB Shocks, Belltech Dropped Spindles (2 in drop), and Global West Del-a-lum bushings. Expensive parts but they are the best out there, as a word of warning if you get their upper A-Arm bushings you have to get their A-arm rod (the one that holds the arm to the frame, whatever its called) the stock one won't work. I learned the hard way, my car is up in the air with no front end, I've got a local shop pushung the bushings and I found out about the rod at 5:15 on Friday, ran home and called Global West hoping to get something here today but no go. Worst part is I need the car monday And it will be Wednesday before I can get them installed. Sad
82 El Camino SS 383
"Build for torque and horsepower will take care of itself"
I like Cobras...They taste like chicken
Steve84Ec
Necoa #: 1529
PostPosted: Fri Jan 09, 2004 2:34 pm    Post subject: Reply with quote
does anyone happen to know anything about the PST ground zero springs? I found them for 95 for the front pair and another 95 for the rear. Anyone know if they are a good brand or not? thinking about making these my new springs. I really need some bad, and that 200 for all four springs is looking good to me(bank account is getting real low) Any replies are always appreciated!! Happy
87SS
Administrator
Administrator
Necoa #: 128
PostPosted: Fri Jan 09, 2004 3:07 pm    Post subject: Reply with quote
Spring & Things
$65 - $80 front pair
$60 - $65 rear pair
Tommy
Director Region 5
Director Region 5
PostPosted: Fri Jan 09, 2004 4:20 pm    Post subject: Reply with quote
Will they lower the car? If so how much?
Camino80
Necoa #: 931
PostPosted: Fri Jan 09, 2004 8:00 pm    Post subject: Reply with quote
Steve, I've had the Ground Zero in for three years now and no problems. But also replaced all the bushings and front end parts, sway bar and shocks. They all work as a unit and replacing just one piece my not get the results your looking for. Also as long as the front end is in pieces I would go all the way. I think I paid about $650 for everything including Edelbrock IAS shocks (from Summit). The bushings were the "super polygraphite kit". p-s-t.com. JMHO Cool
Hansmanbo
Director Region 5
Director Region 5
Necoa #: 1052
PostPosted: Sat Jan 10, 2004 7:41 am    Post subject: Reply with quote
I got a pair of front springs for a big block A body. $40.00 bucks. Cut off one coil for stock height and solid ride! Poke Tounge
WarPony
Necoa #: 395
PostPosted: Sat Jan 10, 2004 9:58 am    Post subject: springs Reply with quote
I purchased a set of rear springs form Moog and they are great! P/N 5391. They are stiff enough that the air shocks don't even need air in them.
Jeff
78 El Camino SS, NECOA #395.
Moe
Necoa #: 1261
PostPosted: Thu Jan 15, 2004 4:37 am    Post subject: rear coils Reply with quote
If you can get rear coils out of a Malibu wagon, it'll lift you 2-3" at least.
They fit, I've done it. My parts car is a '79 wagon for my '80 el camino.
I highly recommend it. Smile
Alchemist
Necoa #: 1756
PostPosted: Sat Jan 17, 2004 5:37 am    Post subject: Re: rear coils Reply with quote
And that's EXACTLY what i'm looking for! LET THE QUEST BEGIN!!!
Tommy
Director Region 5
Director Region 5
PostPosted: Sat Jan 17, 2004 9:56 am    Post subject: Reply with quote
Thats what I had. I changed them because I don't like the "jacked up look" any more. Cool I am a 1 1/2 lower in front & stock height rear with air bags.
elky1982
Necoa #: 798
PostPosted: Wed Feb 25, 2004 11:51 pm    Post subject: springs Reply with quote
i have a set of spring that will fix your elky they are used out of a 2000 s10 they will fix i will sale u.
nowukno
Necoa #: 2160
PostPosted: Thu Feb 26, 2004 2:34 am    Post subject: Reply with quote
Im looking for springs to lower my malibu wagon 1'to1.5' if anybody has some they want to get rid of,let me know please!!!
Page Generation: 0.357 Seconds
