El Camino Central :: View topic - Spool or mini-spool?
Goto page Previous  1, 2
Tommy
Director Region 5
Director Region 5
PostPosted: Fri Mar 12, 2004 4:07 pm    Post subject: Reply with quote
Rich, let us know how you like the powertrax when you get it.
PostPosted: Sat Mar 13, 2004 9:41 pm    Post subject: Reply with quote
I don't anything about the Powertrax, a Detroit Locker is for a Ford 9" rearend , an Eaton posi is rebuildable, an Auburn is not. If you plan on leaving your engine pretty much stock, the 7.5" rearend will survive until it just wears out...you can replace it with a Eaton or Auburn posi unit. Some other options that would be better than the stock rearend would be an 8.5" out of a Grand National, Buick Type T or Olds 442 G-body (these are bolt in and sell used if you can find one usually between $600-$800) also a 12 bolt Chevy rear can be used if you get aftermarket control arms. If you plan on modifying the engine, depending on how drastic you get, you definately want to consider something other than the 7.5"
Mrapii
Necoa #: 2314
PostPosted: Sat Mar 13, 2004 10:54 pm    Post subject: Reply with quote
Mike where can you get a 8.5 GN rear diff with posi? I've looked and looked and couldn't find one. If you have a source I would sure like to buy one. A while ago you had a message in which you said you had a source for modified 9" Ford housings real reasonable, can you tell us where?
PostPosted: Sun Mar 14, 2004 1:49 am    Post subject: Reply with quote
Do I know where there's a 8.5" is right now...no...could I find one tommorow...who knows, probably! "Search" is a wonderful tool. There are other websites similar to ECC that deal with GNs' Type Ts' and 442s'. They also have their "classifieds section" I found ECC through "search". Anyway type in G-body websites in search and about 5 or 6 different websites dealing with GNs' and Type Ts' will come up. Look in the classifieds of those sites. Also check Ebay "parts and accessories" for differentials. It may take a couple of hours looking but I'll bet you could find a couple of 8.5s for sale at any given time using all the resources availble. There's a WEB RING also for G-bodies that probably lists several possible sources for finding one. It's been awhile since I looked for a 8.5''. I didn't like the idea of paying upwards of $600-$800 bucks (going price) for a rearend that might need to be rebuilt. I've decided to go with a 9" Ford. And yes I have a source for bolt-in 9" Ford housings. These are brand new bare housings set up for the new larger Ford bearings, they run for $280 + $35 for shipping. The guy that fabricates them is temporarily out because they had to get the rest of the shop work caught up. I just talked to him 3 days ago. He'll have a couple ready for sale soon...and sorry to say, I'm first in line, then I'll post his website here...sorry! I've researched this and I think that I should be able to assemble a 9" Ford for around $1350 minus the brake set up and using a Strange iron case and resplined 31 spline axles with a GM bolt pattern, most of the parts are availble from the the guy selling the housings. It would cost about another $200-300 for the brake set up depending on what type of brakes are used. This is almost $1000 less then what Moser, Currie, and a few others sell their assembled housings for minus the brakes.
Mrapii
Necoa #: 2314
PostPosted: Sun Mar 14, 2004 2:23 am    Post subject: Reply with quote
Hey Mike what do you think of these brackets/spring perch? Speedway Motors 9" Ford Axle Brackets Do you know what width axle housings will fit 5th Gen El Caminos? If I can get a 9" Ford axle with the proper width I could get into a Ford axle cheap.
Mrapii
Necoa #: 2314
PostPosted: Sun Mar 14, 2004 2:31 am    Post subject: Reply with quote
Oh I also ran across this:Rear Disc Brake Kit for Ford 9" Housings The price seems very good especially since it includes 4 piston calipers. What do you think?
PostPosted: Sun Mar 14, 2004 7:31 pm    Post subject: Reply with quote
Buick Grand National 8.5" rearend for sale on Ebay...item #2465244118 nice, but expensive! 2 days left $600+
Mrapii
Necoa #: 2314
PostPosted: Sun Mar 14, 2004 10:34 pm    Post subject: Reply with quote
Thanks Mike. I'm going to contact the seller and see what the shipping would be to Hawaii. A local guy here is selling the rear axle assembly out of an !985 Monte Carlo SS. It should be an 8.5 with 3.72 gears and if it has posi I'll try to buy it.
PostPosted: Mon Mar 15, 2004 1:52 am    Post subject: Reply with quote
Only Buick Grand Nationals, Type Ts' and Olds 442s came with the 8.5". Monte Carlos did not have them.
b4black
Necoa #: 1856
PostPosted: Mon Mar 15, 2004 5:46 am    Post subject: Reply with quote
And only from 1984 and on for the 8½".
You have want to figure out your goals before shelling out money for an 8½. I plan on 13's for one of my cars, before moving on to another. For that, a 7½" should be plenty.
Rich
1983 Regal T Type
Mrapii
Necoa #: 2314
PostPosted: Mon Mar 15, 2004 5:58 am    Post subject: Reply with quote
Yes they were 7.5". Didn't all '85 up SSs have 3.73 and most of them with posi?
Tommy
Director Region 5
Director Region 5
PostPosted: Mon Mar 15, 2004 6:12 am    Post subject: Reply with quote
Yes, all 7.5 . From what I have read, 85 up were all 3.73s but posi was still always just a option.
Page 2 of 2
Page Generation: 0.346 Seconds
