El Camino Central :: View topic - 700 r4 lock up switch
crash landing
Necoa #: 2361
PostPosted: Wed Mar 24, 2004 1:14 pm    Post subject: 700 r4 lock up switch Reply with quote
i have a 700 r4 tranny going in with lock up...im curious since it is going into a elco that had a 231 v6, will i need a switch to activate the od gear..I know b&m makes one..The column doesnt have a notch for it..I really would like to stay with a colum shift ...
PostPosted: Sat Mar 27, 2004 5:30 pm    Post subject: Reply with quote
TCI sells a kit to make the OD work in your Elky.
Read this: Universal TCC Lock-Up Kit for 700R4 and 2004R
acauth1
Site Admin
Site Admin
Necoa #: 124
PostPosted: Sat Mar 27, 2004 6:15 pm    Post subject: Reply with quote
Here's some other good links
http://www.highperformancecars.com/crosley/lockup1.htm
http://www.technicalevolution.com/700inst.htm
Orfunauto
Necoa #: 1260
PostPosted: Sat Mar 27, 2004 8:59 pm    Post subject: Do it yourself 700R4 over drive hookup! Reply with quote
1. Remove the pipe plug from the fourth gear pressure port. If you have a 200, the plug is located on the right side of the transmission, to the left of the servo cover at about the 7:30 position. You may need an adapter for this; some transmissions have different size plugs. Or if you have a tight fit, you may need to use a ninety-degree elbow.
2. Install apressure switch that you can purchase at CarQuest. The part number is CPS 80466 (I paid $27.25 for it). If you don't have a CarQuest, you can purchase the switch from Stewart Warner as part number 76054.
3. On the left side of both transmissions behind the shifter rod, is a switch that has two (sometimes three) terminals on it. If at all possible, get the factory wiring harness that plugs into this switch from a donor car. The front terminal (terminal towards the front of the car of the factory wiring harness) should be either red, or brown with a black tracer stripe. That wire should be routed to either terminal of the switch you just installed on the right side of the transmission. The next wire of the factory harness should be either purple or black. This wire should go to a GOOD grounding source. A third wire may be present on the factory harness. That wire was used for a high gear signal to the computer. Cut or tape that wire off, it is not used.
4. Run a wire from a twenty amp fused source, that is hot when the ignition switch is in the run position only, to the remaining terminal on the switch you installed.
5. Enjoy!
68 Norton Fastback
Page Generation: 0.292 Seconds
