El Camino Central :: View topic - No luck w/ my EGR valve
jsatcher
Necoa #: 2827
PostPosted: Mon Apr 05, 2004 7:30 pm    Post subject: No luck w/ my EGR valve Reply with quote
My 81 El Camino's EGR valve's gone bad. Its a 267, and AC Delco no longer makes the valve. I've tried other brands, but it just runs worse w/ them on. Any ideas on what I can do to fix this? Any help is greatly appreciated.
Tommy
Director Region 5
Director Region 5
PostPosted: Wed Apr 07, 2004 4:09 pm    Post subject: Reply with quote
Did you try one for a standard 305? I have one on my 350 that doesn't work, it's just for looks.(Emmision tests).
Hansmanbo
Director Region 5
Director Region 5
Necoa #: 1052
PostPosted: Wed Apr 07, 2004 5:24 pm    Post subject: Reply with quote
Whats an EGR valve????????? Laugh Laugh Laugh Laugh Laugh Poke Tounge
eighty_five_el_camino
Necoa #: 2438
PostPosted: Wed Apr 07, 2004 6:44 pm    Post subject: Reply with quote
If nothing else, try the bone yard untill you find one that is good
They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety.
Benjamin Franklin, Historical Review of Pennsylvania, 1759
Iceman
Necoa #: 520
PostPosted: Wed Apr 07, 2004 6:57 pm    Post subject: Reply with quote
EGR, it's on top of my list of emission controls I love to hate. When it works properly, it reduces the performance of your engine, when it doesn't work properly, engine performance becomes more of a suggestion than certainty. Fortunately, I haven't owned many vehicles with this parasite installed and the few I've had, I left everything connected but blocked the passages with a thin sheetmetal plate under the valve. That way I didn't have any vacuum leaks, exhaust gas leaking past the valve and by leaving the electrical connector connected, I didn't have any "Check engine" light in the dash and the powertrain control module was none the wiser since it can only monitor electrical circuits and not the amount of gas going through the valve.
How this system gained popularity among automakers is beyond me, in almost every case it does more harm than good. Intended to reduce the amount of NOx (oxides of nitrogen) from the engine, it kicks in at part throttle during cruising, letting exhaust gas into the combustion chamber to dilute the air/fuel mixture to lower chamber temperature. High combustion chamber temperatures create these NOx emissions and I've always felt that this system was invented in a hurry. Combustion chamber designs from the late seventies and up are quite up to the task of burning the air/fuel mixture more efficiently so pre-ignition is not likely to occur, even with slightly higher temperatures.
Gudmundur Eyfells.
'68 El Camino
'69 El Camino
'04 Dodge Dakota
"I don't know where I'm going but they'll tell me when I get there."
jsatcher
Necoa #: 2827
PostPosted: Wed Apr 07, 2004 9:18 pm    Post subject: Reply with quote
As far as emissions, they don't look to see what I got under the hood, but they test my exhaust. Will blocking it off hurt me in my tests? Also, if I run w/ no valve, won't it take forever to get my car warmed up and ready to go?
b4black
Necoa #: 1856
PostPosted: Thu Apr 08, 2004 6:02 am    Post subject: Reply with quote
I hooked up a scan tool to my car. When I was going down the hiway, the knock sensor was couting up continuosly. (You can't here this knocking at 75 mph). These knocks reatrd timing, which means less performance. Replaced the EGR, the knocks are gone. Unless you can find another way to remove knock, keep the EGR. (or maybe you like replacing headgaskets Shocked )
I don't see how it hurts performance. At WOT, it's closed.
Rich
1983 Regal T Type
doz
Necoa #: 2665
PostPosted: Thu Apr 08, 2004 10:02 pm    Post subject: Reply with quote
Ive seen you post this stuff a couple times about the EGR fixing your knock problem.. There are other ways. Obviously if your engine knocks @ higher rpm you have a problem somewhere. Might wanna check other things IMO.. Theres plenty of engines that run w/ no knock w/out egr's. Mine doesnt knock, and no egr on it ;/ But its a 406
b4black
Necoa #: 1856
PostPosted: Mon Apr 12, 2004 9:13 am    Post subject: Reply with quote
Obviously I have a problem???
Every shop manual I've read points to a bad EGR causing knock. The EGR lower combustion temps to lower NOx. Higher combustion temps lead to knock. Simple, IMO.
I don't have a problem with knock unless my EGR goes bad again. Your 406 is a poor example in this case because it not running the same type of engine management system. IF I could richen the mixture at part throttle, I could get rid of the knock, but then emissions would go up and MPG down.
Yes there are ways to get rid of knock. A functioning EGR is one way. And it not at higher RPM's, it's at part throttle that the EGR is in effect. It's disabled at high RPM's. Dealing with WOT knock is entirely different issue (timing, octane, compression, ignition, etc.)
Rich
1983 Regal T Type
Tommy
Director Region 5
Director Region 5
PostPosted: Mon Apr 12, 2004 5:09 pm    Post subject: Reply with quote
An MSD box is another way to get rid of a slight knock.
b4black
Necoa #: 1856
PostPosted: Tue Apr 13, 2004 5:44 am    Post subject: Reply with quote
Yes, ignition upgardes are a good way to deal with WOT knocking, especially when you can adjust the advance (retard based on RPM). The MSD did nothing for my part throttle knock. I already had colder plugs, new 8mm wires, new cap/rotor and a hotter coil. Timing is factory.
I went though three EGR valves (I wouldn't recommend TOMCO). When each failed, it caused part thottle knock. New valve = no knock.
Most poeple unhook their EGR and never even consider part-throttle knock becuase you usually can't here it. But hook up a scan tool and you will see it (a scan tool is an excellent investment, IMO). It's not as damaging as knock at WOT, but it happens much more often (acute vs chronic).
Rich
1983 Regal T Type
Page Generation: 0.336 Seconds
