El Camino Central :: View topic - A/C compressor test
A/C compressor test
Randy135
Necoa #: 2744
PostPosted: Wed May 12, 2004 8:55 am    Post subject: A/C compressor test Reply with quote
Is there a way to test an A/C compressor to tell if it is good or not before installing it in the car?
And also, what would cause the V-belt on an A-6 compresser to squeel when the system cycles on and also under accileration? It has a new correct belt installed and tension is right.
Your help is appreciated
blcknslvr86
Necoa #: 3128
PostPosted: Wed May 12, 2004 4:50 pm    Post subject: Reply with quote
Possible bad A/C clutch could be causing the squeal. When the system is not cycling, there is no resistance. When the clutch is trying to engage, the internals of the pump could be dragging and causing the pully to stop moving and then will get the wonderful screech and squeal. As for the pump check, not sure on that. Sorry. Hope I helped a little bit at least.
Randy135
Necoa #: 2744
PostPosted: Fri May 14, 2004 10:39 am    Post subject: Reply with quote
Thanks for the info. I thought it might be the the clutch, but wasn't sure. Are they hard to replace? And can it be done without opening the system?
The A/C is cooling good right now.
Thanx, Randy
acauth1
Site Admin
Site Admin
Necoa #: 124
PostPosted: Fri May 14, 2004 12:18 pm    Post subject: Reply with quote
Not really, you can turn it with one hand while having a couple fingers from your other hand covering the suction and discharge ports and check that it actually pumps. Not a reliable method, nor are there any.
Wrong width belt, rust in the v-belt grooves, rust on the hub and pulley surfaces, incorrect clutch gap, pulley bearing, or bad compresser.
No, they aren't hard to replace and you do not have to discharge the system. You will need a clutch hub puller, a pulley puller and a clutch hub installer. You can probably rent these somewhere.
Randy135
Necoa #: 2744
PostPosted: Fri May 14, 2004 3:49 pm    Post subject: Reply with quote
Thanks very much, that helps alot
Page Generation: 0.326 Seconds
