Posted: Thu May 22, 2003 10:18 pm Post subject: Well this certainly sucks
Well got me so 15" camero rims bought the lugnuts, put the rear ones on.....man those look nice! Put the front ones on RUBBING THE IDLER ARMS!!!!!!! So off they come and back to where they came from and get my money back, talk about depressed, they sure looked good though _________________ race prepped 350 .040, msd ignition(6-AL, billet distributer, MSD Blaster 2), L-31 vortec's, .488/.488 lift cam, 670 street avenger, air gap intake, roller rocker arms, TH350, 2500 stall, 3.73 gears. Exxon loves me!
Are these the IROC rims? Did you use four front IROC rims or did you get a stock set from an IROC? The backspacing is different for the back IROC rims.
The front 15" IROC rims have a 0 offset (4.5" backspacing) so they should fit OK on all four corners. The rear 15" IROC Rims have a 16mm positive offset (4.9" backspacing). If you put the backs on the front they will rub. I've got four fronts on my 87 Elky.
_________________ Ernie
