Posted: Sun Oct 10, 2004 9:03 pm Post subject: GM 5.3 with 4L60E Trans
I'm a new member with a 5th generation plane jane that has a 4.3 V-6. It's really in pretty good shape. Since I have never read anything about pumping up the V-6, I have to assume it probably not very benificial. I'm not looking to build a Monster Machine, just generate some good smooth power and not have to deal with the Smog Nazi's. I found a great buy on a 5.3 V-8 including trans, wiring harness, and computer removed from a 2001 Silverado. (Haven't bought it yet) Do any of you have experience with this motor swap? I've owned a Silverado 4X4 with this power plant combination, I believe the perfomance I'm looking for will there. I'm just trying to pick your brains on how difficult this conversion will be.
Necoa #: 478
Posted: Mon Oct 11, 2004 5:36 am Post subject: Re: Poltergeist
My 86 Camino with the 4.3 is TBI so the fuel tank should work, correct?
The fuel system will be OK.
I assume the motor mounts shown in some the forum posts moved foward in the engine bay for the 350 installs are what your refering too.
No, you will need V8 mounts and then a plate to connect to the new mounts to the Motor. The LS series of motors has the mount in a different location then the old style small blocks.
The present tranny is a 200, new mount, right?
Yes
Is there a post explaining the ECM reprogramming or harness modification?
Not that I want to direct anyone away from here but you might want to go to www.ls1tech.com look about halfway down and there is a Hybrid section. Start doing some searches there and you can find out about the oilpan, mounts and harness info. People there have put the LS series motors in all kinds of things. You can spend a few days with searching for info in the older posts. _________________ '82 El Camino with an LT1 from a 95 Impala SS
