El Camino Central :: View topic - Edmonton members?
Edmonton members?
Post new topic   Reply to topic    El Camino Central Forum Index -> Region 21 Canada (West of Ontario)
Bloodline
Necoa #: 3874
PostPosted: Tue Nov 02, 2004 3:30 pm    Post subject: Edmonton members? Reply with quote
Any members in Edmonton?
elky-man
Necoa #: 813
PostPosted: Sun Dec 05, 2004 12:52 am    Post subject: Yes, I live here in Edmonton Reply with quote
gilc lives in Edmonton. What's Up?
1980 GMC Caballero Diablo
Fifth Generation El Camino Owners Group
Bloodline
Necoa #: 3874
PostPosted: Tue Dec 07, 2004 11:59 am    Post subject: Reply with quote
Good to see there is at least one other member in Edmonton. Maybe some time when the weather is more favorable we could get together and chew the fat over a beer or coffee. Is that an '80 you own?
elky-man
Necoa #: 813
PostPosted: Wed Dec 08, 2004 12:39 am    Post subject: Since you are asking... Reply with quote
Yes, car is a 1980 GMC Caballero Diablo. Currently in the garage getting the entire body sanded for a repaint in the spring. Other winter projects include new floorpans, carpet, interior door panels, headliner, seat covers to change interior colour from maroon to black. I have also been trying to learn about acoustic and thermal insulation to keep the interior quiet as well.
In the spring before the repaint, will also order the rear rollpan with the Z1R corvette tail lights. Plan to install a new sound system and as of yet unknown type wheels/tires.
Currently the engine is a 4 bolt 350 with all new rings, bearings, seals with new oil pump, windage tray, 224/234 @0.050" cam, Edelbrock performer intake, Holley 670 electric choke single pumper, Flowtech headers and 2.5" exhaust. The tranny is a THM350 with all new B&M frictions and steels, seals/bushings and a Trans-go shift kit. also have a B&M starshifter installed.
The rear is still the 7.5" OEM with Richmond 3.42:1 gears and Posi. The rear end is held in place with South Side Machine lower control arms to help move the instant centre back a bit for traction. Someday I will install a 9" Ford rear end but not this year.
I am also looking into a rear disk brake swap from a newer chev blazer if I can find the parts in the wreckers.
I live in the Castledowns area of Edmonton, where are you located?
Bloodline
Necoa #: 3874
PostPosted: Thu Dec 09, 2004 1:45 pm    Post subject: Reply with quote
Very interesting. I also have a 1980 El camino Classic which I purchased
late September. My car appears to be the same color as yours (was originally white) and has a maroon interior also.
The car came equipped with a 396 out of a 1968 Chevelle and is bored .060 over with a 500cfm Edelbrock carb (2 barrel I think but I have not checked as of yet). The intake manifold and exhaust manifolds are stock. The car came with an Edelbrock intake manifold but was not installed because the previous owner said there was not enough clearance under the hood - need to measure to be sure but judging by the clearance now he is probably correct. The cam is not stock but I don't know the specs although I have the part number off an invoice which also included re-sizing of the rods - need to check it out. The motor was completely re-built in 1996.
The car also came with a 3-core aluminum rad, aluminum driveshaft, electric fuel pump and fuel regulator valve. The rear end appears to be out of an S10 ( based on paper that came with the car) and has 3.73 gears and an aftermarket locker. The transmission is a 350TH with a 3500 stall converter and a shift kit but the components are not B&M.
I am contemplating similar work as you have described. The car is scheduled to go in for paint on Monday(couple of minor rust spots in the box) and after that is going for custom guages, new carpet, new headliner, some work on the door panels as well as having the seat re-upholstered and a floor shift put in. I am thing of introducing a lot of tan into the interior to lighten it up and go with the existing maroon.
I have been to quite a few shops investigating the quality of work and pricing - none are cheap, as you probably know, but some appear more reasonable than others - a lot depends on exactly what quality you are looking for. I am looking for good to very good street quality as opposed to show quality which for myself is prohibitively expensive.
Maybe we can compare note on shops and prices.
What color are you thinking of for paint? I would assume that because you are changing the interior color ( maroon is a tough one) you are also going to change the exterior color. I haven't completely settled on a color as of yet but was thinking either a real vibrant red or a shade of orange with some red and brown undertones. Maroon is definitely a limiting color interior wise as it relates to selecting an exterior color. I want a color that you don't see everyday and that will have a "hotrod" kind of look.
Also, if you know where a lower front valence could be sourced(other than the US) it would be much appreciated. I have probably phoned 30 or more wreckers in Alberta, Sask. and BC as well as GM with no luck.
I live in the westend, about 2 minutes SW of West Edmonton Mall (Aldergrove).
elky-man
Necoa #: 813
PostPosted: Fri Dec 10, 2004 1:25 am    Post subject: Edmonton Member Reply with quote
Bloodline;
It seems that for paint, you get what you pay for. To keep costs down, I try to perform as much of the body work myself as possible. As far as any mechanical work, I do all of it.
I work for a company here in Edmonton that builds wheelchair accessible vehicles and we employ welders and auto body techs. So they give me alot of advice about panel welding, sanding, and body prep. I also have a two door down neighbor that owns a welding company and always keeps a Mig welder in his garage for me to use in exchange for golf and beer.
The maroon exterior colour of my car is paint code 75, Claret. The car was originally two tone Claret and Dark Claret. but is all one colour now. I like the Claret and will keep the colour as it is easier and cheaper not to do a colour change. To do a proper colour change, the insides of the front fenders and doors should be painted as well.
As for the air dam, my Diablo used to have one but is long gone now. I have installed a regular small black pastic air deflector from a Malibu to keep the air flow directed into the radiator.
The urethane air dam is still available at a few places like the El Camino Store in California. I have ordered various parts from them a few times and never had a problem with anything. What I usually do to keep my shipping and customs brokerage down is to order parts when I am in the USA on business and have the parts sent to my hotel and bring the parts back on the plane.
Kid-K
Necoa #: 6016
PostPosted: Sat Aug 27, 2005 12:07 am    Post subject: Reply with quote
i have a 1981 i also live in edmonton
Bloodline
Necoa #: 3874
PostPosted: Wed Aug 31, 2005 7:06 am    Post subject: Reply with quote
Cool. maybe we will see each other on the road. How about a little more info like color, etc. How much do you drive it? Is it stock? Mine had a lot of work done on it when I got it, not all of it correct - so i am still sorting out issues about one year later.
1980 El camino 396
Kid-K
Necoa #: 6016
PostPosted: Sun Sep 04, 2005 1:53 am    Post subject: Reply with quote
this is my car...i drive it pretty regularly ..it in no way is meant to be a show car...just did enough work to it to make it presentable...i'm 17 so this was a big job for me and i think i did good...if you see me on the road give me a honk or a wave
the engine is a 305 which i rebuilt...it runs well but am thinking of putting a 350 in it next summer along with a manual trans and a posi rear end with at least 345 gears.....i don't plan on having this car stock ..although for now i don't have money for very much modification.....hard to make some decent dosh at 17...know any good jobs lol ?
Kid-K
Necoa #: 6016
PostPosted: Sun Sep 04, 2005 2:01 am    Post subject: Reply with quote
3.42*
outlaw17
Necoa #: 6542
PostPosted: Thu Dec 08, 2005 11:21 pm    Post subject: Reply with quote
I live in Edmonton too , first post for me . I dont have an elky yet but I have access to a 68 with no frame , so... I came here for some details before I go get it !
Royal Knight
Necoa #: 7978
PostPosted: Sun Aug 13, 2006 12:48 am    Post subject: Rear window Tint Reply with quote
Hey, if any of you have had your rear windows tinted, could you help me out. Ive been looking all over for a place to do it. Ive been quoted at $300!!! just for the rear. Any places i should try?
elky-man
Necoa #: 813
PostPosted: Tue Aug 15, 2006 9:46 pm    Post subject: Rear Window Tinting Reply with quote
A few years back, I had a guy at Windshield Surgeons at 82 Ave and 50 Street here in Edmonton look at my back window for tinting. If I remember correctly, he wanted $150.00 to do it. I decided to try the $18.00 Canadian Tire limo dark film do it yourself route. With the shape of the 1978-1987 back window it is hard to get into the corners. It did come out ok but not perfect.
I have the back window out right now to paint the body and will likely get the window tinted professionally this time.
Allocer
Necoa #: 12142
PostPosted: Sun Jul 20, 2008 5:55 am    Post subject: Reply with quote
Hi i live just out side of edmonton, i dont own a elky yet but im going to look at a 77 sprint soon.
Post new topic   Reply to topic    El Camino Central Forum Index -> Region 21 Canada (West of Ontario) All times are GMT - 6 Hours
Page Generation: 0.357 Seconds
