El Camino Central :: View topic - Tail Light Lens Screw Removal?
purpelcam69
Necoa #: 4499
PostPosted: Tue Jan 11, 2005 7:02 pm    Post subject: Tail Light Lens Screw Removal? Reply with quote
The screws on my '69 are screwed up! I have new lenses, however I can't get the screws out. I tried spraying them, I tried that Sears screw extractor but all it did was round out the + in the heads. Can they be drilled out or do I need to buy new tail light housings? Any help out there?
Bobs 81
Necoa #: 1510
PostPosted: Tue Jan 11, 2005 7:44 pm    Post subject: Reply with quote
What I've done in the past is to try and drill the old screws out, using a drill size about the size of the head of the screw. Drill just far enough to remove the head of the screw, then remove (pry off) the old lens and then you can get at the rest of the screw and use more spray, let it soak, and then you should be able to use a pair of pliers/vicegrips to remove the rest of the screw. Hint: when you reassemble the new lens, I always put a dab of anti-seize on the screws. Hope this helps. Bob
81 conquista 350-700r4, changed frame, yr4 of 3 yr project
82 EC 229 soon to be nephews first car/truck
79 EC 305 2bbl 700R/4 daily driver
Central lower Michigan
purpelcam69
Necoa #: 4499
PostPosted: Wed Jan 12, 2005 10:36 am    Post subject: Reply with quote
Sounds like a plan Bob. I'll give it a try. Thanks, Barry
rod123
Necoa #: 4212
PostPosted: Thu Jan 13, 2005 3:16 pm    Post subject: easy out Reply with quote
I have had good luck using an easy out, drill hole down center of screw and backtwist in easy out, works most of the time if you have applied plenty of penetrant oil.
Thanks Rod
86 Choo Choo
85 Choo Choo
68 XL GT
77 280 Z
purpelcam69
Necoa #: 4499
PostPosted: Fri Jan 14, 2005 6:22 pm    Post subject: Reply with quote
Thanks Rod, this sounds good too. I live in NJ and have to work outside so I think i'll wait till the weather warms up a little.
JDCamino82
Necoa #: 4175
PostPosted: Fri Feb 04, 2005 10:30 pm    Post subject: Reply with quote
hey, what i have sometimes done with a stuck screw is use a drimel tool with a thin cutting disk, i cut a slot all the way across the srew so i can just use a flat head driver to get it out. it might not work in your situation with the light covers being right there, but it works on many other situations. hope ya figure it out Smile
