Posted: Tue Mar 15, 2005 12:30 pm Post subject: mounting brackets
i am ordering a sanden sd-508 from jeggs for my 79. will i be able to install using all the brackets and hoses and hardware, or there is something extra to buy. i am a do it myself,risk taking home mechanic, so i ask before i do.tks.
But you can make it happen. I designed a mount for mine and had it cut from aluminum. Then a local shop made the lines and I had them run them behind the fenderwells and under the front header panel so you could hardly see them. I used an aftermarket parrallel flow condensor and drier so that's not stock either.
Here's some pictures that may give you some ideas. Some are a little blurred but I think you'll get the idea.
