Posted: Thu Mar 24, 2005 11:42 pm Post subject: vacuum can bracket clip
On the vacuum can of a 1970 camino chevelle ect... there is a bracket that screws onto the AC. The bracket has a small clip. that holds the edge of the vacuum can onto the bracket. I saw a few cans with the bracket and clip on Ebay, but they are going 60 to 80 dollars, and all I need is the clip.
Does anyone know where to get just the clip?
thanks for any help. _________________ 1970 El Camino 396 SS - Fantom Blue (was white - it's now blue again),
blue interior bench, factory posi, TH400
1970 El Camino 396 SS - Emerald Green
black interior buckets, TH400
I think I found the answer to my own question; I believe there is not actually a clip, but instead there is tabs on the bracket that are bent into place and holds the vacuum can to the bracket. my tabs are broken off on one side. _________________ 1970 El Camino 396 SS - Fantom Blue (was white - it's now blue again),
