Yes, it is normal. When the defroster is running, so is the AC compressor. The carburetor is equipped with a fast idle solenoid that is energized anytime the AC compressor is on. The solenoid prevents the carb linkage from traveling all the way to the low idle position. Of course, the engine idles faster with the AC system running also.
You can test this for yourself. Turn on the defroster. Come to a complete stop. Listen carefully to the engine RPM's. Turn off the defroster. Observe the drop in idle speed. By the way, it's a good thing. Be grateful it works correctly. One less thing to fix!!! _________________ 86 caballero, 350 cid, TH350C
Necoa #: 3296
Posted: Tue Apr 05, 2005 4:45 pm Post subject:
You need some idle step up to compensate for the extra load on the engine with the A/C compressor on.
Actually in a perfect world your idle would not change, but in an analog/mechanical world you only get so close. With more recent cars with computerized EFI you get no idle speed change, just throttle change.
Still depending on how far it moves, I would look into verifying that the A/C system is really working. Your idle would go too high if there is no load from the A/C compressor for example. If you get cold air on A/C then you are probably fine here. Next after that I would check if the idle stepup mechanism has any adjustability built in. You may be able to reduce the amount of throttle movement at the stepup position. _________________ Project: '68 El Camino SS 396 clone w/4spd
