El Camino Central :: View topic - so heres the problem, my heater wont turn off.
84Caballero
Necoa #: 3100
PostPosted: Tue Apr 05, 2005 10:48 pm    Post subject: so heres the problem, my heater wont turn off. Reply with quote
when ever i am driving i can feel heat coming from either the floor vents or the defroster vents.....and the fan isnt running.....and i can hear a hissing noise coming from the heater. it hasnt always been doing this, it just started this winter.
if anyone could help that would be awesome. cuz summer is coming.
84 GMC Caballero
View user's profile Send private message Visit poster's website AIM Address MSN Messenger
jmhollis
Necoa #: 4629
PostPosted: Fri Apr 08, 2005 9:39 pm    Post subject: Reply with quote
Hot water circulates through the heater core all the time on some models, others have a vacuum operated water flow valve in the engine compartment. Another vacuum operated diverter causes air to either pass thru the heater core to the passenger compartment or blocks the airflow. Sounds like you may have a problem with the diverter actuator or the vacuum line from the heater control lever assembly to the actuator, or perhaps a bad valve on the dash mounted lever assembly. This leak will be the source of the hiss. It's not too hard to get in there and check the system out - but do it before it's 100 degrees in the garage!
84Caballero
Necoa #: 3100
PostPosted: Thu Apr 14, 2005 11:26 pm    Post subject: Reply with quote
so where is the diverter actuator and such? i dont know much about the heater and it components.....haha....
84 GMC Caballero
PostPosted: Fri Apr 15, 2005 12:07 am    Post subject: Reply with quote
I still have the vacuum operated valve on my 74. It's a kind of L shaped tube with a small vaccum line running to a disk shaped vacuum housing. One side of it is a tube that runs up to the vacuum disk and then there's a tube that comes out of the center of the vacuum disk that hooks to my heater hose that goes back to the firewall where my heater core hooks up.
The other kind of setup is likely on the back of your AC slider assembly. Buried within the bundle of vacuum hoses that plug into that slider will be one vacuum line that goes to a diaphram cannister that contols the opening and closing of the door that sits in front of the heater core located inside the ductwork on the firewall.
Just a shot here but I know for sure about the one on the intake manifold.
Smile
84Caballero
Necoa #: 3100
PostPosted: Sun Apr 17, 2005 11:08 pm    Post subject: Reply with quote
just out of curiosity....is there like an "easy fix" like until i have time to work on it....like is there anyway, i can stop heat from entering the cabin? cuz i hate not being able to control the tempreture in my car.....and it sucks cuz my a/c went out last year....so i can't cool it down...but yeah....if u know of anything else that would be amazing
thanx, you're awesome.... Smile
Alex
84 GMC Caballero
acauth1
Site Admin
Site Admin
Necoa #: 124
PostPosted: Sun Apr 17, 2005 11:26 pm    Post subject: Reply with quote
Alex
Pinch off one of the heater hoses to prevent hot water from entering the heater core.
szonk
Necoa #: 5244
PostPosted: Mon Apr 25, 2005 10:18 pm    Post subject: Reply with quote
heck just take the heater box out of the loop. Drain system, disconect both heater hoses then cut yourself a 12 to 14 inch bypass and hook that up to water pump / manifold outlets
Chillin in Lauderdale
84Caballero
Necoa #: 3100
PostPosted: Mon Apr 25, 2005 11:15 pm    Post subject: Reply with quote
that sounds like a RAD idea, but won't it be a big pain in the rear end to put back in when winter comes back around?
84 GMC Caballero
trimpedavo
Necoa #: 4845
PostPosted: Tue Apr 26, 2005 9:20 pm    Post subject: See my post on tips and tricks Reply with quote
It doesn't make any sense but it worked.
Davo
