El Camino Central :: View topic - anybody removed a/c box on '74
horror
Necoa #: 1226
PostPosted: Thu Sep 22, 2005 3:57 pm    Post subject: anybody removed a/c box on '74 Reply with quote
hi
own a '74 elky,
want to remove the a/c box completely since I don't use it, and have easier access to the rear end of the engine for maintenance.
anyone ever done this????
Also wonder what's the use of the thing ( sender?) which is located on the left side of the box, into the bracket of the vacuum cannister, which has two wire attached to it, a green and a green/white.
Can I swap the 'plate ' from a non a/c car on mine or maybe make one myself? Will I still have fresh air or only heat?
Low75
Necoa #: 4203
PostPosted: Fri Sep 23, 2005 12:31 pm    Post subject: Reply with quote
I removed mine from my '75 and installed an American Graffiti delete box. http://americangraffiti.biz/
With this you can get rid of the A/C and still use the heater.
horror
Necoa #: 1226
PostPosted: Fri Sep 23, 2005 3:57 pm    Post subject: anybody removed a/c box on '74 Reply with quote
hi,
looks great, but a bit expensive....will think 'bout it.
do you still have fresh outside air into the car, or only heat?
where did you leave the resistor-block from the fan?
and the sender i was asking, do you know what's the use of it?
Low75
Necoa #: 4203
PostPosted: Fri Sep 23, 2005 5:40 pm    Post subject: Reply with quote
Fresh outside air? That is what windows are for. Are you asking if the AC will still funtion after you remove the box? No it will not, only your heater. The resister/relay are reinstalled on the box. I'm not sure what sender you are talking about, maybe fan speed controller? I'm not really too up on the AC components, which is one of the reasons why I deleted it.
