I think on my 75, there are two wires that come out of that switch; one is the back up light switch and the other is the neutral safety switch. You may want to check if the car starts in drive. My reverse lights don't work because when the gearshift was moved from the steering column to the floor, the new gearshift was not hooked up. Also, there might be corrosion in the bulb housings.
