El Camino Central :: View topic - 1983 Caprice 305hp fuel pump
Raven
Necoa #: 4843
PostPosted: Fri Apr 29, 2005 8:10 pm    Post subject: 1983 Caprice 305hp fuel pump Reply with quote
Iam removing the fuel pump, i read my Chilton book and it said to remove the upper mouing boss bolt, then insert a bolt to hold the push rod, where is this bolt? do you have a photo of hte location?
( small block chevy)
thanks!! Raven
fix things now, not later when the problem get worse, good luck!
Raven
Necoa #: 4843
PostPosted: Fri Apr 29, 2005 8:14 pm    Post subject: Reply with quote
what size is the wrench to remove the fuel filter line from the carb,
my 5/8in fit to wide, is it metric? or a odd SAE?
greywolf
Necoa #: 64
PostPosted: Fri Apr 29, 2005 9:53 pm    Post subject: Reply with quote
Yes, Chevy changed to metric size hardware.
2HF
Necoa #: 3963
PostPosted: Sat Apr 30, 2005 4:30 am    Post subject: Reply with quote
I changed the fuel pump on my [1984] 305 and there was no upper bolt and yes the push rod slid down a bit which prevented the new pump from going in [it doesn't fall into an unknown pit]. No big deal, once I got the slippery devil back where it belonged and somehow managed to hold it in place the pump installation was a snap.
As long as you are working with the fuel line consider changing the fuel filter in the Q-Jet.
Fun isn't it! Happy
Our El Camino is a 1984 Conquista Smile with about 46.7k miles, 95% stock, and for sale.
A couple pages of pictures at: http://www.elcaminocentral.com/modules.php?set_albumName=2HF-Project&op=modload&name=Gallery&file=index&include=view_album.php
NJLuke
Necoa #: 1221
PostPosted: Fri May 06, 2005 11:02 am    Post subject: Reply with quote
Or you can take off the mounting plate itself, then put the pushrod in place, and install the plate, and pump at once. alittle easier than jimmying with it for an hour. good luck!
Oh yeah, make sure if you are installing a aftermarket performance pump that you put a pressure gauge somewhere so you know if it puts out more than 6. My holly out out something like 10-12 and would flood the carb!
-Luke
Keep on Truckin'
Orfunauto
Necoa #: 1260
PostPosted: Fri May 06, 2005 6:36 pm    Post subject: Holder Reply with quote
What they are saying, is that there is a bolt on the front of the engine, just around the corner from the fuel pump. There are actually two holes on the front of the engine. The top hole lines up with the fuel pump rod. On the later model engines, the top hole has a short stubby bollt screwed into it. Remove that bolt and install a longer bolt. FINGER TIGHT ONLY or you will scar the pump rod. This will hold the pump rod in place when you remove the pump. Much easier than trying to push the rod back up into place when it falls down.
For the younger folks, those two holes were originally the motor mount bolt holes for the early models. Don't forget to replace the bolt with the shorter one after you're through installing the pump.
68 Norton Fastback
dave1987SS
Necoa #: 3869
PostPosted: Thu May 19, 2005 7:28 pm    Post subject: Reply with quote
When I replaced my fuel pump I did not know about the short bolt, I found an easy way to do it was to put a blob of grease on the pushrod and jam it up into the hole until it reached the cam, the grease held it in position until I got the fuel pump bolted in, and the grease will not damage the inside of the engine, it mixes with the oil and dissolves out in your next oil change.
Dave
84 G camino
Necoa #: 5583
PostPosted: Mon Jun 20, 2005 9:58 pm    Post subject: another tip Reply with quote
if the pushrod doesnt seem to want to go back into the hole at all, BUMP SLIGHTLY the ignition or better yet spin the crank bolt to rotate the engine till the cam lobe is down, then the rod will give a bit more.
rob
84 camino SBC shiny heads and more than 10 bolts
View user's profile Send private message AIM Address MSN Messenger
Tazz
Necoa #: 5410
PostPosted: Sun Jul 03, 2005 6:20 am    Post subject: the bolt on the front of the engine.... Reply with quote
just around the corner from the mounting plate for the fuel pump is a small/short 3/8 bolt...remove that bolt and get a bolt with longer threads ...this will hold the push rod once you put it way up into the slot it ride in and keep it there...don't forget to remove the bolt with the longer threads and install the short bolt once your done....the push rod won't like the longer bolt at all!!!
Tazz
Tazz
mattnificent
Necoa #: 2924
PostPosted: Sun Oct 02, 2005 11:23 pm    Post subject: Reply with quote
i did the grease thing but put it in the freezer for a lil bit so it would be nice and thick and sticky......worked good........ Cool
Getting up early didnt work out too good for the worm.....
Raven
Necoa #: 4843
PostPosted: Sun Nov 13, 2005 12:26 pm    Post subject: Reply with quote
thanks for the info, on the fuel line, i went to sears and bought 5/8 flare nut wrench and it worked.
Page Generation: 0.333 Seconds
