El Camino Central :: View topic - GM Tech's - Injector ?
87SS
Administrator
Administrator
Necoa #: 128
PostPosted: Thu Dec 08, 2005 8:28 am    Post subject: GM Tech's - Injector ? Reply with quote
Guys;
My son has a 94 Olds 88 3.8 V6 with one or more fouled injectors. Will injectors from 95 LT1 work as a short term fix? I've got a spare set. I'm just trying to save him some money. Thx
old_coot
Necoa #: 3943
PostPosted: Thu Dec 08, 2005 11:22 am    Post subject: Reply with quote
injectors are rated by the number of pounds of fuel per hour they can deliver and the computer is set for a specific rate so while the injectors may physically fit they will run the cylinder either lean or rich depending on how for they sized. lean can cause detonation damage in that cylinder and rich can wash out the rings---you need to make sure both cars use the same rating before you do it------An easier choice might be to go to the parts house and get a product called Seafoam---its primarily a carbon remover but it also has fuel injector lubricant in it---if the injector is stuck and not burned out --it may do the trick for something like 6-7 dollars..................Dan
STARFIRE350
Necoa #: 4622
PostPosted: Wed Feb 08, 2006 5:17 pm    Post subject: Reply with quote
I just ran the part numbers and no they are not compatible according to GM
87SS
Administrator
Administrator
Necoa #: 128
PostPosted: Mon Feb 13, 2006 11:55 am    Post subject: Reply with quote
I ended up sending the spare set as cores up to Linder Tech Injector service in Indianapolis...since I only needed 6 for Olds and I sent 8 they upgraded to the better Bosch injectors at no charge...nice folks to deal and great turnaround as well.
Page Generation: 0.286 Seconds
