El Camino Central :: View topic - Noisy AC compressor
Noisy AC compressor
spoonplugger
Necoa #: 1271
PostPosted: Fri Aug 15, 2003 10:17 pm    Post subject: Noisy AC compressor Reply with quote
Help! The AC compressor on my 86 Caballero has developed a loud growl/low frequency vibration at idle speed only. Above idle and there is no noise. The system works fine. A new (not reconditioned) compressor was installed in 2000 at the same time the system was converted to R-134. I took it to the installer and he said he thought it needed a new belt. Changed the belt, but did not help. I also snugged all mounting bolts, etc. Installer said he does not know what the problem happens to be. Any ideas??
86 caballero, 350 cid, TH350C
acauth1
Site Admin
Site Admin
Necoa #: 124
PostPosted: Sat Aug 16, 2003 8:32 am    Post subject: Reply with quote
Sounds like a crapped out compresser. Did your mechanic bother to checked system pressures? Could be a bad fan clutch causing too high pressure either making the compresser noisy at idle, or could have trashed it. Regardless, have your guy check the pressures.
spoonplugger
Necoa #: 1271
PostPosted: Sat Aug 16, 2003 6:16 pm    Post subject: Reply with quote
I did have a thermal fan clutch go bad late last summer, but the temps did not reach extreme levels. The temp would climb to 210 to 215 around town but wold cool off on the freeway. Finally traced the problem to a bad thermal clutch which I replaced. Is it possible that temps in this range could cause damage to the compressor?
acauth1
Site Admin
Site Admin
Necoa #: 124
PostPosted: Sat Aug 16, 2003 10:52 pm    Post subject: Reply with quote
Yes, if you were running the a/c with a bad fan clutch.
Check your system pressures.
Page Generation: 0.295 Seconds
