El Camino Central :: View topic - Engine Ideas
Engine Ideas
n1earnhrt
Necoa #: 1365
PostPosted: Fri Aug 22, 2003 11:02 pm    Post subject: Engine Ideas Reply with quote
I can't decied weather to improve the perfomance of my 229 V6 or to build a V8. I need this to be a daily driver and reliable. If I do put in a V8 what size would work best. I want around 400 hp This will be going in my 1980 El Camino.
Any help would be appreciated
Don't worry about yesterday when you have today to live
1985 GMC Caballero (Current Project)
1986 Chevy El Camino (Current Daily Driver)
1979 Suzuki GS750L
Visit My Gallery
mistaconquista
Necoa #: 1383
PostPosted: Fri Aug 22, 2003 11:06 pm    Post subject: Reply with quote
can't go wrong with a 396, but if you can't find one, a 327 is good and is easy to upgrade/build upon.
Reluctantly crouched at the starting line
my elky, thumping and bumping in time
The flags go up and the cars take off
I leave all the Fords sucking down my exhaust
They cheer for the car, they cheer for the guy
With his RPM's low and his MPH high.
View user's profile Send private message Visit poster's website AIM Address
PostPosted: Sat Aug 23, 2003 4:20 am    Post subject: Reply with quote
You can build a reliable 350 capable of 400 hp, and not at a great expense.
n1earnhrt
Necoa #: 1365
PostPosted: Sat Aug 23, 2003 8:19 pm    Post subject: Reply with quote
Thanks everybody also should I put a manuel or automatic transmission
1979 Suzuki GS750L
Visit My Gallery
PostPosted: Sun Aug 24, 2003 6:37 am    Post subject: Reply with quote
Putting in an automatic or a manual trans is a decision only you can make. Only you know what you want your car to do and how to perform. If you want to maintain your car in as near as to original, you would probably want to stay with an automatic if that's what's in there now. You can buy a very good automatic trans, capable of handling the torque of a 400 hp engine. If you like to slam gears, then a manual shift trans is the way to go. Keep in mind that finding parts to convert it to a manual is not all that hard, but can be a little difficult and a little expensive, the stock bellhousing being the hardest part to find, and a good 4speed trans being the most expensive part. I have all the parts to convert my auto to a manual. I searched long and hard to find these parts and at the price I paid. You may not be as lucky as I was, and in fact you may be able to get a competition automatic 350 or 400 THD from TCI or B&M at cosiderably less cost than what you will need to convert it to a manual trans (if you buy a new 4 speed manual trans at $1300+ and then tack on the price of a flywheel, clutch and pressure plate, another $350-$500). Then there's the problem with the rearend to consider if you convert to a 400hp engine and a manual trans, the stock rearend in your Elky was not designed to take a lot of abuse, not for long anyway. You would need to change that, it may last for awhile, but not long, especially if you start dumping your clutch at 5500 rpm more then once or twice. It's something that takes a lot of thought. Hope this helps. Smile Oh, and and far as your original question goes, yank the 229 and use it as a paper weight or a boat anchor or something. Cool
ElkyPete
4th Gen Group Moderator
Necoa #: 3
Year: 1976
PostPosted: Tue Aug 26, 2003 8:38 am    Post subject: Reply with quote
What type of transmission do you have in your truck now, a 350C?
You can build a good 350 with decent Hp pretty reasonable. The Vortec heads will deliver up to 400 Ponies unmolested and a bit more if you change the springs up. The Vortec are good heads and are priced really good. A complete set shouldn't cost over $500.00 new. I'd look into getting a new design block that will take factory roller cam and lifters and a one piece rear main seal.
If it is going to be a daily driver then I would suggest an overdrive transmission. 700R4 or the 200R4 then change the gears in the rear end to a 3.73:1 or 3.90:1, 4.10:1. Add a Posy or a Powertrax to the openface that you probably have.
That will get you a little stop light fun and good overall gas economy on the highway. Total cost probably wouldn't be more than $4,000.00 to $5,000.00 complete. Use good parts you could probably do it cheaper but your starting with "basically" nothing. So 4 to 5 grand is not a lot of cost.
Make sure that you know the machine shop's work. Don't get any Tom, Dick or Harry to do the work for you. Do as much as you can yourself. If you get the right block from the right Junk yard you could get by without having to buy new pistons. Just ridge ream, glaze brake and hone check for defects and there you go you're ready.
Just my $0.02 worth.
n1earnhrt
Necoa #: 1365
PostPosted: Fri Sep 05, 2003 4:42 pm    Post subject: thanks Reply with quote
Hey thanks everybody I planing on going with 350 and putting in a stroker kit, Haven't decided on a manuel or atmatic but it will come down to the price of it. What car could I get a new rearend or should I get it from the aftermaket?
1979 Suzuki GS750L
Visit My Gallery
