Necoa #: 5555
Year: 1967
Posted: Sat Apr 01, 2006 12:12 am Post subject: help on tpi bolts
can anyone tell me which bolts go where on a 305 tpi. i dont what to buy the book just for the bolts. is there a web site or something i could go to for free.
thanks
Check this web site www.chevythunder.com I think I recall that the location of the bolts was covered as part of the installation of a TPI. If you look at the flang on the runners you can pretty much figure it out when you us the stainless steel bolts you only us two sizes the long ones go to the thick flang and the shorter ones go everywhere else. But the web site is more detailed and will help with the locations. You will also find a lot more info to use. you can also check www.thirdGen.org Good luck Harald K
