El Camino Central :: View topic - vibration on deceleration
deangod
Necoa #: 701
PostPosted: Sat Oct 11, 2003 9:01 pm    Post subject: vibration on deceleration Reply with quote
I just noticed this today... say I'm cruising along at about 60 or so and I let off the gas. The whole car starts to shake, but stops if I give it enough gas to maintain or increase speed. It doesn't seem to do it if I shift to neutral, but I only tried that at a lower speed (I didn't know if the tranny would like it so much if I did it at a higher speed). Another strange thing is that if I'm at a stoplight and then go, the car seems to want to pull to the right until I let off the gas slightly, then a clunk comes from the front suspension (or so it sounds) and the car straightens up. I've heard the clunk one other time while backing out of a parking spot.
So anyways, does anyone have any idea what could be causing these things? I'm gonna crawl up under there tomorrow, but I thought I'd ask here first to see if I can get a few possible starting points.
Thanks in advance for any guidance.
-Dean
P.S. If it makes any difference, the tranny's a 350, recently replaced the front U-joint. I haven't touched anything else lately except for the distributor and the carb when I timed it and set the float level/idle.
Tommy
Director Region 5
Director Region 5
PostPosted: Tue Oct 14, 2003 9:32 am    Post subject: Reply with quote
I had a simuliar problem on one of my Chevelles. The last time I had it aligned the guy did not tighten the bolts enough & the alignment shims fell out causing the upper a arm to move around. Look at that & the a arm bushings cause they could be shot.
87SS
Administrator
Administrator
Necoa #: 128
PostPosted: Tue Oct 14, 2003 9:59 am    Post subject: Re: vibration on deceleration Reply with quote
Check your upper and lower ball joints before you drive it again. Make sure your castle nuts are torqued to spec and the cotter pins are in place. I dropped a front lower a few months back without any warning. Thank gawd I had just pulled into my regular spot at work! Shocked
87SS
Administrator
Administrator
Necoa #: 128
PostPosted: Thu Oct 16, 2003 8:01 am    Post subject: Re: vibration on deceleration Reply with quote
Monday I noticed a slight shimmy at 47 mph in drive. Figured with 154K it was the tranny getting ready to "give up the ghost". Crawled under the car when I got home to check the universals & such. Grabbed the drive shaft to check for play and the whole tranny slid from side to side. Looked at the tranny mount thinking it had worked loose. Nope, shot to sh#t...guess what I'll be doing Saturday! Figured I'd swap the u-joints at the same time as well just as preventative maintenance.
PostPosted: Thu Oct 16, 2003 8:40 am    Post subject: Reply with quote
Definately sounds like a front end problem of some sort deangod. Check ball joints, control arms, and all steering linkage. Something(s) under the front end has definately passed its lifetime or is loose or not aligned...idler arm maybe? 87SS...I'd go with the polyurethane transmount.
deangod
Necoa #: 701
PostPosted: Thu Oct 16, 2003 9:21 am    Post subject: Reply with quote
Hmm, I guess I'll take a look at the front susp.... Didn't get a chance to last weekend because I ended up getting free tickets to the IRL race at Texas Motor Speedway. So, I'm driving the car very, very sparingly this week.
Have any of you guys tried the front end rebuild kits from Performance Suspension Components (http://www.performancesuspension.com/)? I figure I might as well rebuild the whole thing if I'm replacing ball-joints (rather do it all at once than have something else fail in 2 weeks).
Thanks for the info!
-Dean
PostPosted: Thu Oct 16, 2003 9:39 am    Post subject: Reply with quote
Dean, probably a wise move and I'd go with the kit with the polyurethane bushings, a bit more expensive but it will handle better and last much longer.
87SS
Administrator
Administrator
Necoa #: 128
PostPosted: Thu Oct 16, 2003 10:39 am    Post subject: Reply with quote
The only thing I use anymore...I'll be checking those pesky motor mounts as well after seeing the condition of the tranny mount.
baggedlco231
Necoa #: 1825
PostPosted: Wed Nov 19, 2003 1:57 am    Post subject: vibe on dec Reply with quote
is ur lco bagged? if so a 4link 2link or just bags?
Page Generation: 0.325 Seconds
