El Camino Central :: View topic - Electrical Basics - Part 3 - Crimp Connectors
John D
Necoa #: 2784
Year: 1964
PostPosted: Wed Jul 12, 2006 9:06 pm    Post subject: Electrical Basics - Part 3 - Crimp Connectors Reply with quote
(This'll probably generate a zillion posts "I've been doing it this way for years....." but, I'll put dollars to dimes with 15 years of making low-voltage connections on life-critical circuits that this is a reliable way - maybe not the "best" - time/money/materials withstanding... to make good & reliable connections)
Crimp Connections.
Far too many of us are chasing electrical gremlins. I’ll wager that 90% of the hair-pulling going on is due to poor connections. The other 10% is truly a defective component.
Basically there are 2 types of electrical connections:
Physical
Mechanical
Physical: A “Physical” connection is an electrical connection achieved by “bonding” the conductors via welding or soldering. The two (or more) conductors are permanently connected by melting or bonding. The joint cannot go bad unless the point of connection physically fails or is broken.
Mechanical: A “mechanical” connection is an electrical connection achieved by friction, crimping, or contact. The connection relies on the contact (touching) of two conductive mediums to make a circuit. Herein are most of the problems.
(Failure of a “physical” connection is obvious. You have a broken wire or connection point at a device. Most of this text will deal with “mechanical” connections, which brings us to….)
What makes a good “Crimp Terminal Connection”, and how to do it!!
Crimp Connector 101
Crimp connectors are wonderful things. An easy, inexpensive way to make what would be a difficult or expensive connection. We all have the remnants of a $ 1.99 assortment pack floating around the workshop. There are also 199 ways to make a WRONG connection with a crimp terminal or 99 cent tool.
*** “Scotch-Lok” Connectors***
These things should be banned. They are the plastic things you stick one wire through, the other into, and squeeze with a pliers. They were designed so U-Haul could make quick connections for trailer rentals, and have NO PLACE ANYWHERE for making a good, permanent electrical connection. Now that my personal pet-peeve has been aired…..
Crimp/Stripper Tools:
Just about everyone has an “electrical connector multi-tool” in their kit. They will have an assortment of stripper gages, and crimping dies. They usually fall into one of two types:
A. A cutter, and 2 or 3 “elliptical” crimp dies at the tip, with stripping dies after the hinge.
B. Pliers, then stripping dies, a cutter, then 2 or 3 “peg and ½ circle” crimping dies after the hinge.
Look for a tool that has what I call the “peg and ½ circle” crimping dies. It’s usually the “B” type (Craftsman #82563) and has a rounded “peg” on ½ the tool, and a mating ½ circle on the other half.
Stay away from the tools that use the “1/2 ellipse - smash” type dies. They won’t produce reliable crimps and are usually junk! Look and buy a good tool!
Stripping Wire:
This seems to be an overly-simplistic thing, but too many people do it WRONG!
A. Choose the strip die to match the wire gage
B. Look at your connector – only strip off as much insulation as needed to expose copper to the mating surfaces of the connector.
C. Close the tool around the wire squarely
D. Squeeze (cutting the insulation)
E. Let up a bit on the “squeeze” and pull the insulation off.
A properly stripped wire will have only as much insulation needed removed (bare copper won’t be visible outside the connector), the copper strands will still be compacted, and not have any nicks or strands cut loose!
Crimp Connectors:
A. If a properly stripped wire won’t slide into the hole of a connector, you have the wrong gage connector! DO NOT cut off wire strands to make the wire fit into the connector – get the proper size connector!
B. Don’t try and use an oversize connector for a small size wire – you won’t get a reliable connection.
C. There is an “upside” and an “upside-down” to a crimp connector. Look at the connector or inside the round hole. The round hole is formed by rolling flat metal into a circle, and you will usually see a seam (remember this – see Crimping).
Crimping:
A. Properly strip your wire.
B. Insert the bare conductors into the connector (make sure there are no “strays” hanging out).
C. Orient the connector with the seam “up”.
D. Put the crimp tool on the connector, with the “peg” on the OPPOSITE side of the seam, in the middle of the crimp area.
E. Squeeze firmly.
F. Tug on the connection to verify a good crimp.
This is why I prefer the “peg & ½ circle” crimp. By design, the crimp pushes the “meat” of the connector up into the wire, and “rolls” the seam down into the center. It results in a very firm mechanical connection.
The “1/2 ellipse” crimp dies just smash the connector down on the wire, not “rolling” the connector’s metal around the wire. The “ellipse”style crimp allows the wire to slide to the sides and not get mechanically crushed to the connector body.
(Most “factory” crimp connections are made with a specialized tool/die that form a “B” shaped crimp, with a secondary crimp on the insulation (stress relief) of the wire. This is done with and automated machine, and the connectors are on a strip or “gun belt” feeding the machine. These connectors and corresponding crimping tools are available on a “one’sy – two’sy” basis through specialized outlets, but are expensive! A hand tool with dies to crimp 18ga. and 20ga. wire is about $95.00, and you’ll have to buy about 200 connectors.)
'64 Elky, 383, TH-350, 12 Bolt,
'65 Elky, 327, 'Glide, PS/PB
"Think you used enough dynamite there Butch?"
Mrapii
Necoa #: 2314
PostPosted: Thu Jul 13, 2006 11:34 am    Post subject: Reply with quote
That's a good primer on electrical connections. I know a lot of people will tell you that they never use crimped connections because they are unreliable. The fact is a good crimped connection is perfectly acceptable; some maybe surprised to find out that crimped connections are the primary method for making repairs in the aircraft industry.
Duts87ss
Necoa #: 5020
PostPosted: Fri Jul 14, 2006 7:58 am    Post subject: Reply with quote
GM also used crimp connections in there wiring harnesses. Personally, I still prefer soldered connections when I've got the room to get both hands and the soldering iron in position.
Dustin
John Harris
NECOA National Director
Necoa #: 78
PostPosted: Fri Jul 14, 2006 9:52 am    Post subject: Reply with quote
An outstanding job of explaining how to do this critical work! My Elky had so many bad connections and/or ground problems when I bought it that hardly anything worked.
How about the soldering aspect? Can you recommend a good soldering tool that is not too expensive and small enough to use inside the engine compartment? What are the opinions on that "Cold Heat" soldering tool that is advertized on TV for aobut $20.00? Can that do the job?
View my El Camino
PaPa Johns 77
Necoa #: 6188
PostPosted: Fri Jul 14, 2006 11:27 am    Post subject: Reply with quote
Cool Thats a great question! It would be perfect for working under the dash! I personally prefer to solder my connections. Cool
"Still Just Truck'in"
"Johnny"
Bradley, Illinois
83Elky
Necoa #: 331
PostPosted: Tue Oct 03, 2006 12:44 am    Post subject: Crimp Connectors Reply with quote
Re the question on the "Cold Solder" device: my experience with one was less than positive. It would not adequately solder anything larger than about 22 or maybe 20 gauge. IMHO worthless for most anything around an automobile.
Dan
JDCamino82
Necoa #: 4175
PostPosted: Sun May 13, 2007 3:52 pm    Post subject: Reply with quote
Very true about properly crimped wires are perfectly acceptable, I've also heard that crimped connections are used in aircraft industry, but because of heat issues would melt soldering.
Page Generation: 2.604 Seconds
