Necoa #: 5673
Posted: Sat Oct 14, 2006 6:15 pm Post subject:
Nice!!!
I've had traction problems too and and am considering something similar for my 70.
Mill is a 454/TH700 with 3.55 posi, and did have 14" dia BFG T/A radials (235-60's I think). Might have well been on roller skates.
A few months ago I upgraded to M/T E/T Street radials (275-50-15's) in the rear on 10" wide rims. Traction went way up but could still be better.
$60 was reasonable enough for that kind of improved bite. How difficult was the install? The pic makes it look easy enough.
Auto trans or manual? What kind of engine do you have and how's the torque on the bottom end? (what I'm getting at is are you sure the improved bite didn't cause the engine to now drop below it's low end torque limit?).
Thanks. _________________ 70 Elky (Non-SS) 454CID, TH700-R4
29 Model A (Recently Sold).
Do you have adjustable upper control arms so you can correct the pinion angle? Appears with these brackets you would have dropped the front of the pinion more than just a few degrees.
There very easy to install, no loss of torque if anything I gain torque.
Engine Block : 4 Bolt 880 ZZ 4 Rollor 350 30 over = 355
460 hp and 450 lbs/ft of torque
Pistons: TRW Forged 11:1
PM connecting rods
Crank: TRW Forged
Edelbrock Aluminum Performer RPM Heads
Edelbrock Performer RPM Manifold
Edelbrock Performer RPM Hydraulic RollorCam 238 548
Crane Aluminum Roller Rockers 1.5
Trans: 700R4 With A 373 gear and A B&M Shift Kit, Art Carr 3000 stall
Header: Dynomax with Flomasters
MSD: Ignition 6 AL Box.
Carb: Holley 750.
I do have adjustable uppers, but was told thay well work without,
thay where made to work with stock lower control arms.
LINK
Heres my baby link below
84 Camino _________________ http://elcaminocentral.com/gallery-album_album107.html
