Posted: Sun Oct 29, 2006 7:28 pm Post subject: Tilt Steering Column Tips
I have a 84" Caballero.. The other day I was truning the ignition key, and the rod to the Ignition switch popped off up in the column. I got a repalcemnt column from a junk yard, and now I can't figure out how a little spring goes in at the Bright Light Switch....Help!!!..
