El Camino Central :: View topic - air does not come out front dash vents
e_16
Necoa #: 9396
PostPosted: Sun Apr 15, 2007 1:58 pm    Post subject: air does not come out front dash vents Reply with quote
My heat and A/C work, but they will only come out of the vents under the floor and against the windshield. It is not coming out of the vents that are in the dash...any ideas on how to fix this?
PostPosted: Sun Apr 15, 2007 6:32 pm    Post subject: Reply with quote
Find the vacumn line form the engine up to the little black ball, which is a resevoir, and follow that line and look for a break. sonds like you have no vacumn to the control.
K5Cruiser
Necoa #: 6708
PostPosted: Mon Apr 16, 2007 6:27 pm    Post subject: Reply with quote
Do as suggested by 464elky. The flaps that direct the cold or hot air are operated off of vacuum. You have a vacuum leak somewhere, which is causing the flaps to not operate. Take some time took look at all of the vacuum lines in the engine compartment, and you'll probably find that there are quite a few that need replacement due to cracking from heat, etc.
e_16
Necoa #: 9396
PostPosted: Mon Apr 16, 2007 6:31 pm    Post subject: Reply with quote
is this black ball next to the A/C accumulater...if it is, the black plastic thing going into looks like it is melted shut...can i just cut the melted end off and place it back in the ball?
PostPosted: Mon Apr 16, 2007 8:27 pm    Post subject: ball Reply with quote
Yes it is by the accumulator. Pull the small line off, about an 1/8 inch plastic, and start the engine. you should have vacuum at the connection on the ball. If not pull the large hose off and see if it has vacuum coming from the engine. If you have it at the outlet of the ball the break is between there and the control switch. If you don't have any on the larger hose it is broken or pulled loose down toward the manifold.
slywun
Necoa #: 9367
PostPosted: Thu May 03, 2007 12:03 am    Post subject: Reply with quote
I have the same issue, found the leak (the thin colored vacuum line was split in 2 under the dash).
Where can I get a new line? I've had no luck with any of the retail stores.
Thanks,
KB
1987 El Camino SS Choo Choo
2005 Cadillac CTS-V
Mr86Camino
Necoa #: 4450
PostPosted: Thu May 03, 2007 7:18 am    Post subject: Reply with quote
A simple fix for the plastic hose is a rubber hose as a splice. Just take a small piece of the plastic hose to the parts store and find some rubber hose that is a tight fit to go over the plastic hose. The rubber hose may not last 20 years but your plastic hose did not last that long either. The good news it will be easy to find.
1986 El Camino
1985 Porsche 911
Page Generation: 0.306 Seconds
