El Camino Central :: View topic - Pulled the trigger, '96 LT1
Jive 65
Necoa #: 8106
Year: 1965
PostPosted: Sun Jun 24, 2007 5:11 am    Post subject: Pulled the trigger, '96 LT1 Reply with quote
Just picked up an LT1 from a 96 Impala SS. Complete with serpentine bracket & accessories, radiator & fans, harness & computer and 4L60E trans. Package has 60k, and I stole it for $1000!
I have a vent line on the side filler on the 65 gas tank. I plan to T the return into it.
I plan to use an external electric pump, what capacity do I need?
I have a set of Hooker headers (2451) Will they fit the heads? I know I will need to weld in O2 sensor bungs.
It looks like the headers made for the Impala are designed to tie into the stock cats. I have both cats, I can cut the converter off and use the inlet pipe with the O2 sensor. Jim's performance said he can reprogram the computer for 2 sensor operation, along with set up for my gear ratio and eliminating the immobilizer & other not needed alarms.
Comments?
Bob Weis
Astatula, FL
'65 Chopped & Dropped
Some Motorcycles
dcar
Necoa #: 8364
PostPosted: Sun Jun 24, 2007 10:39 am    Post subject: Re: Pulled the trigger, '96 LT1 Reply with quote
Jive 65 wrote:
Just picked up an LT1 from a 96 Impala SS. Complete with serpentine bracket & accessories, radiator & fans, harness & computer and 4L60E trans. . . .Comments?
Yes - you don't need this, and I'll give you $1,001.00 - - that's a profit! Shocked When can I pick it up? Poke Tounge
Jive 65
Necoa #: 8106
Year: 1965
PostPosted: Sun Jun 24, 2007 2:05 pm    Post subject: Re: Pulled the trigger, '96 LT1 Reply with quote
LOL, that wouldn't even cover the gas money it took to pick it up! Laugh
Bob Weis
Astatula, FL
Some Motorcycles
Bowtie
Necoa #: 4669
PostPosted: Sun Jun 24, 2007 7:56 pm    Post subject: Reply with quote
You're absolutely right! Dcar is a cheapskate! I'll pay for your gas. Poke Tounge
FYI, there is a significant difference between a vent line and a return line. A return line operates under pressure and a vent is not intended to be. Depending on your vent configuration, you could create a dangerous condition. Be vewy, vewy sure of your plan.
Take care.
84 Elky GTA
Jive 65
Necoa #: 8106
Year: 1965
PostPosted: Mon Jun 25, 2007 5:59 am    Post subject: Reply with quote
Take care.
Thanks Bowtie. My 65 has a side fill tank that has a 1/2 inch vent next to the filler tube. the hose goes up to the top of the filler neck, about 12" above the tank. Do you think that could be a problem? I can install a bulkhead fitting in the tank if that would be better/safer.
Bob Weis
Astatula, FL
Some Motorcycles
Bowtie
Necoa #: 4669
PostPosted: Mon Jun 25, 2007 9:55 am    Post subject: Reply with quote
I have an 84 5th Gen with a TPI so I am not familiar with the actual parts of your 65 as many of our members are. No doubt there are many threads herein on the exact conversion you are making.
That said, I am not aware of any professional and safe design that has a return that must constantly drain down the filler tube. Don't think I'd be comfortable with it.
Two considerations:
1. Research the conversion in the Forum. I'll bet there may be an EFI sender unit w/ return and vent that someone has found works fine in your tank.
2. The bulkhead fitting in your tank may be a fine option. Sure you remember that a spark from a drill plus an old tank with fumes equals BOOM.
Hope this helps a little. Keep us posted.
Take care.
84 Elky GTA
dcar
Necoa #: 8364
PostPosted: Mon Jun 25, 2007 10:29 am    Post subject: Reply with quote
Bowtie wrote:
. . . . .Dcar is a cheapskate!. . . .
And. . . .your point is? ? ? ? ? Cool Besides, I was thinking "negotiations. . ." on the gas. . . Laugh
Jive 65
Necoa #: 8106
Year: 1965
PostPosted: Mon Jun 25, 2007 1:36 pm    Post subject: Reply with quote
Thanks, Bowtie. The vent actually runs along side the filler tube, only ties in near the top. As for sparks, I'll wash the tank out if I go with the fitting, then run a hose from the exhaust of another vehicle while I drill. Back when I lived in the rust belt, I brazed leaky tanks shut using that method, The CO purges the O2 from the tank, no boom!
Bob Weis
Astatula, FL
Some Motorcycles
Poltergeist
Gallery Administrator
Necoa #: 478
PostPosted: Mon Jun 25, 2007 9:03 pm    Post subject: Reply with quote
I used a Walboro 255 pump if I remember right. You need about 40~45psi fuel pressure. The 255 is an internal pump I don't know if you plan on that or an external.
I'm not familiar with the headers you're using but if they will work with a SBC and your engine bay then they will work with your LT1. The exhaust ports are the same.
ECC Member #002
Jive 65
Necoa #: 8106
Year: 1965
PostPosted: Mon Jun 25, 2007 9:23 pm    Post subject: Reply with quote
I picked up this link from one of the threads here: http://www.jimsperformance.com/
I've been in contact with Jim and he has been very helpful, and reasonable on building a harness and reprogramming the computer. He has a Delco external pump available that will work. The 65 tank has the sending unit mounted on the front side, I don't think I can find a unit to interchange that will fit an internal pump.
I spoke with the local guru at the race car fabricating shop, he confirmed the headers will work, as you said the exhaust ports are the same, and he will weld in the O2 sensor bungs.
Bob Weis
Astatula, FL
Some Motorcycles
Bowtie
Necoa #: 4669
PostPosted: Tue Jun 26, 2007 6:31 pm    Post subject: Good timing Reply with quote
It seems your timing is fortuitous (whatever that means). You'll want to go to your local mag rack and buy the August edition of Super Chevy. There is an article specifically about putting LS engines in hotrods.
It's a short worthwhile article and I won't regurgitate it here, except to say the pro's doing these installs all cite the same biggest problem - fuel systems.
I also picked up some interesting trivia, such as 90 degree bends in LS fuel lines are a no-no. They're always frowned upon, but especially on LS's.
Take care.
84 Elky GTA
Jive 65
Necoa #: 8106
Year: 1965
PostPosted: Tue Jun 26, 2007 7:07 pm    Post subject: Reply with quote
August Super Chevy, I'll get a copy, thanks for the tip.
I saw on the Summit site they have AN6 to compression fittings that will compress on the tubes on the fuel rail, and I assume the tank pickup after I cut the 'bulb' off the end. I'll have to look closer, but there may be room to put a bulkhead fitting in the sender plate for the return line. A nice high pressure hose should be easy to run and make the fuel pump connections without severe bends. I used a similar system when I added a fuel cell on one of my bikes for extra capacity.
Bob Weis
Astatula, FL
Some Motorcycles
Poltergeist
Necoa #: 478
PostPosted: Tue Jun 26, 2007 7:25 pm    Post subject: Reply with quote
Go to this page: http://www.performanceplumbing.com/New_Products.html
Go down to part # 5800 this is what I used on my fuel rail. You can pull them off with 'relatively' little trouble. I've been running them since getting my LT1 running with no problems.
ECC Member #002
Jive 65
Necoa #: 8106
Year: 1965
PostPosted: Wed Jun 27, 2007 6:34 am    Post subject: Reply with quote
Very nice, thankyou.
Bob Weis
Astatula, FL
Some Motorcycles
Jive 65
Necoa #: 8106
Year: 1965
PostPosted: Thu Jun 28, 2007 12:48 pm    Post subject: Next Question... Reply with quote
Which motor mounts do I need to drop the LT1 block into my '65? I want to replace them when I do the swap, and I see different listings when I look up the '64 Elky, and the 96 Impala. I only have the metal bracket bolted to the block from the Impala, do I need to use the bracket from the 305?
Bob Weis
Astatula, FL
Some Motorcycles
