El Camino Central :: View topic - WHAT SIZE EXHAUST?
WHAT SIZE EXHAUST?
82lko
Necoa #: 4018
PostPosted: Tue Sep 04, 2007 12:03 am    Post subject: WHAT SIZE EXHAUST? Reply with quote
hey guys, I have a question of my own hopefully u guys can help me. Well here it goes, I'm in search of a exaust system for my elko, the motor that i have is a well built 383 that consist of new AFR 195 eliminator heads, probe forge pistons with 11.5:1 comp, solid roller engale cam with 242 duration, 1.6 roller rockers, 750 demon carb, with a single plane intake manifold, aslo have 1 5/8 dougs headers. As for the driv trian, is a well built 700R tranny with a 3000 vigilantie stall converter. So what size exaust system would you guys recommend? 2.5 w/ X pipe or 3" w/ X pipe. Also what type of mufflers do u recommend.
bigjames4xl
Necoa #: 2409
Year: 1972
PostPosted: Tue Sep 04, 2007 3:10 pm    Post subject: Reply with quote
No brainer, 3" , Flowmasters(50series) are my preference, make sure pipes exit behind the rear wheels or out past the bumper.
Electric cut-outs at the pipe bends before the x-pipe would make for some added fun!!!
Ol Paint and me
454/700R4/3.31 posi
8.30 @ 82.23 / 60ft @ 1.82
AND
14.5 mpg average on HRPT 2006
PaPa Johns 77
Necoa #: 6188
PostPosted: Tue Sep 04, 2007 3:53 pm    Post subject: Reply with quote
Confused What? Confused No Royal Scotts and 2' pipes out the back? Confused
"Still Just Truck'in"
"Johnny"
Bradley, Illinois
bigjames4xl
Necoa #: 2409
Year: 1972
PostPosted: Tue Sep 04, 2007 4:52 pm    Post subject: Reply with quote
Smile Cool Smile
Ol Paint and me
454/700R4/3.31 posi
AND
CANTED
PostPosted: Tue Sep 04, 2007 8:53 pm    Post subject: exhaust Reply with quote
From the Oct/07 Chevy Hi Perf, Kevin McClelland's Q&A . " Should you run 3-inch on your Chevelle? First, Flowmaster dosen't recommend using 3-inch systems on the street because of sound issues. The 2.5-inch system will support up to 450 hp with little or no power loss over open exhaust. You also have much better torque for street use with 2.5-inch tubing. With 3-inch you loose exhaust velocity and torque right where you drive on the street." Kevins words, not mine but I respect what he says.
Jim
bigjames4xl
Necoa #: 2409
Year: 1972
PostPosted: Wed Sep 05, 2007 3:00 pm    Post subject: Re: exhaust Reply with quote
CANTED wrote:
From the Oct/07 Chevy Hi Perf, Kevin McClelland's Q&A . " Should you run 3-inch on your Chevelle? First, Flowmaster doesn't recommend using 3-inch systems on the street because of sound issues. The 2.5-inch system will support up to 450 hp with little or no power loss over open exhaust. You also have much better torque for street use with 2.5-inch tubing. With 3-inch you loose exhaust velocity and torque right where you drive on the street." Kevins words, not mine but I respect what he says.
Noise issues? 2 1/2" can create noise issues!!!
A good compromise is to run 3" to the mufflers then 2 1/2 from the mufflers back.
As for 2 1/2" supporting 450hp with little or no power loss, I'm not buying that, but there are many factors involved though and I think a general statement one way or the other could be wrong for any particular car.. I have 3" pipes about 2' long coming off the headers with cutouts on the end. then 2 1/2 branching off into the mufflers and out behind the rear wheels. I have not yet made back to back runs at the track with the exhaust open as opposed to closed. BUT, if smoke off the drag radials is any indication when playing around on some backroads tire smoke increases dramatically with the exhaust open. My big block has 350hp at the rear wheels so I'm damn close to 450HP at the flywheel. I would think a mild small block may not be as sensitive to exhaust changes but a stroked and roller cammed small block would have to be better with the bigger exhaust, but again, just another generalization.
So in short, if the only issue is too much noise then stick with the 2 1/2", otherwise what's it going to hurt to up it to 3"?
Ol Paint and me
454/700R4/3.31 posi
AND
CANTED
PostPosted: Wed Sep 05, 2007 7:54 pm    Post subject: exhaust Reply with quote
I agree, James. This is something that would be case by case. The guy that asked Kevin the question described his car as a 70 Chevelle with a 350. No doubt a large displacement engine will benefit from the big pipes simply because it pumps more air. I do however like what he said about the exhaust velocity with the 2.5 system. There would seem to be a scavenging benifit like that of a smaller intake runner. A benefit for a street engine that would not apply with a race engine.
Jim
82lko
Necoa #: 4018
PostPosted: Thu Sep 06, 2007 9:24 am    Post subject: Reply with quote
Okay, how about 3"piping with X pipe and magnaflow mufflers, a couple of people told me that magnaflows are quiet and still gives u great performance. Smile
old_coot
Necoa #: 3943
PostPosted: Thu Sep 06, 2007 12:24 pm    Post subject: Reply with quote
My personal choice is to run the 3" to the crossover or X pipe and 2 1/2 on back it makes putting the system in so much easier and does not hurt the power in any way on an engine of this type---thats what I have on my Monte Carlo SS with a 383, th700r4 and 3.73...I run 12.80s through the pipes on street radials....A 383 is a torque motor and seldom sees the plus side of 6000 and unless the head ports are huge you slow it down to go much higher.also after the crossover the flow is more of a continuous flow and less pulsing as with separate pipes all the way back....I have noticed no increase in mph or lowering of the ET with the headers open even----just my personal experience....oh I went with the flowmasters and they are pretty loud at full song but not too bad just cruising...........Dan
Mama Mayhem
Necoa #: 2540
Year: 1971
PostPosted: Thu Sep 06, 2007 12:56 pm    Post subject: Reply with quote
I'm running Magna-flows, not loud on the street until you kick it.
Mama Mayhem's Gallery
I'ma going to EL
15.610 @ 90.31mph 9/8/06
bigjames4xl
Necoa #: 2409
Year: 1972
PostPosted: Thu Sep 06, 2007 4:11 pm    Post subject: Re: exhaust Reply with quote
Yep, and as old coot points out the hybrid of starting out with 3" and reducing to 2 1/2" is a very good option. I don't think it would matter if you reduced before the x-pipe or at the mufflers but it would still make for a good exhaust set up.
Ol Paint and me
454/700R4/3.31 posi
AND
82lko
Necoa #: 4018
PostPosted: Sun Sep 09, 2007 6:51 pm    Post subject: Reply with quote
WOULD CENTER/CENTER STYLE MUFFLER WORK OR DO I HAVE TO RUN OFFSET/OFFSET?
bigjames4xl
Necoa #: 2409
Year: 1972
PostPosted: Mon Sep 10, 2007 2:22 pm    Post subject: Reply with quote
I'm not sure on a 5th gen but my 3rd gen is offset/offset. Lots of variables though unless you go with a complete aftermarket kit specifically for your application.
Ol Paint and me
454/700R4/3.31 posi
AND
Scotts70&72
Necoa #: 10061
PostPosted: Wed Sep 12, 2007 5:43 am    Post subject: Reply with quote
Your exhaust selection will depend a lot on how loud you want your car to be. Another thing to consider is emission testing. I am not familiar with the laws in your state but here in Arizona the pipes have to run to the rear of the bumper or in front of or in back of the rear tire. This is to make it easier for the monkeys at the emission testing station to hook up the sniffers to read your emissions. Also here in Arizona depending on the year of your El Camino, you are also subjected to under the hood inspection to make sure the factory emissions equipment is present.
With the setup you have I would not hesitate one bit to go with a full 3" exhaust with Flowmaster mufflers. Make sure you have the exhaust bends in the pipe mandrel bent. That is one of the biggest mistakes people make when getting exhaust work done. They go to a shop to have the exhaust done and the shop does not do mandrel bends. But again this will dictated by how loud you and your neighbors can live with. Smile
In the hot desert!
82lko
Necoa #: 4018
PostPosted: Wed Sep 19, 2007 2:31 pm    Post subject: Reply with quote
Thanks for all of your inputs, I went with 3" with a x pipe to magnaflow muffler and 2.5" coming out exiting underneith the bumber, sort of like a SS.
Page Generation: 0.373 Seconds
