Necoa #: 9163
Posted: Wed Oct 31, 2007 12:55 pm Post subject: Im buying either these headers or those headers.
Trying to go the cheap route I decided to buy summits Dynomax blackjack painted headers which as far as Summit says the only fitment issue will be a new bracket for the a/c compressor. Here is a link of the headers in case yall are unfamiliar with them.
blackjack headers
now the black jack ones were full length which I'm assuming is better for performance but the next set up in headers as far as price goes, are the Hooker AND Hedman shorty style headers.
ULTIMATELY i'd like to spend as little as possible and go with the black jacks, but if anyone can tell me or convince me why some of these other ones in my price range would be better i'll probably go with them.
Necoa #: 4175
Posted: Wed Oct 31, 2007 4:41 pm Post subject:
i don't see a reason why not to get the blackjack headers unless you can afford ceramic coated headers. the paint will burn off in the first 15 minutes the motor runs , I bought a pair of headers real similar for my el camino when i put a crate motor in it and if I could do it again i would spend another 100 bucks or how ever much to get ceramic coated headers. the others rust and will eventually rust through. DO NOT put that header wrap around them they'll rust even faster. i would not get shorty headers unless there is no way for full length to fit. comparing just the blackjack full length to the hedman full length you listed the blackjacks breath a little better 1 5/8 compared to 1 1/2. i would get the blackjacks
Necoa #: 9163
Posted: Wed Oct 31, 2007 5:44 pm Post subject:
i hear ya, i'll get the blackjacks probably. Im not too worried about the rust...I live in texas. If the headers were just painted and the paint wasnt properly embedded into the header or whatever I can see why it would just burn off. I have painted headers before and it worked pretty good, its supposed to smoke a little the first start up though.
Necoa #: 10275
Posted: Wed Oct 31, 2007 8:11 pm Post subject:
yeah the paint will come off tho... mine came off in bout 3months. shortys are more building torque and tight spaces and full length are horsepower thats what my machinist told me _________________ tim fraley
Necoa #: 9163
Posted: Tue Nov 06, 2007 7:06 pm Post subject:
all well. I ordered the headers and then some "down pipes" to come off them but haven't decided which route to go as far as rear exit, or side exit. I'll probably do rear I just need to figure out what headers to get.
Oh yeah, I am gonna get some cut-outs as well.
I ordered a long aluminized exhaust pipe from summit 2.5 inches diameter, man that thing was heavy...I dont see why it needs to be that heavy.
anyone have experience with this new a/c bracket that is needed apparently?
and does anyone know what to use for these funky rear end header bolts?
Necoa #: 9163
Posted: Wed Nov 07, 2007 6:06 pm Post subject:
69 tremec wrote:
your header flage bolts? is that what you are wondering about?
I was confused actually and removing the wrong bolts, they were more like plugs. I got the headers off for the most part. I cant believe some of the ghetto riggings the previous owner did to this car, its just incredible really.
anyway, I'm still confused how this new A/C bracket is supposed to work maybe it will become clear to me whenever i get the new headers tomorrow.
I dont understand why on one side of the crossmember its crushed but the other side is a full tube, that means i gotta run that exhaust pipe under it.
you have a single exhaust cross member you can modify it if you have the know how or you can buy a dual exhaust cross member going under can create ground clearance problem over the speed bumps it's your call _________________ it's mine it's paid for and i'll smoke them if i want to
If you don't weld or have a welder you could take your cross member to a welding shop and have them modify your crossmember. Just have them make the right side look more like the left side.
click on this thread, there of a photo of a modified crossmember.
When I installed headers on my engine, using a hack saw I cut a section out of the air compressor mounting bracket to clear the header, did not seem to affect the strength of the mount.
Necoa #: 9163
Posted: Thu Nov 08, 2007 9:17 am Post subject:
very nice!! thanks guys, thats alot more appealing than spending 200+ bucks on some aftermarket knotched one. I cant weld yet but should be able to find somebody.
Necoa #: 9163
Posted: Thu Nov 08, 2007 6:47 pm Post subject:
Okay I got the headers today and i've been installing them for the past 3+ hours. I'm not gonna say the fitment is horrible because I know it could be worse...but this is pretty irritating. There is a spot coming off the frame that attaches to the control arm I believe and on BOTH headers one of the header pipes hits it. The instructions act like you can move the motor but its not like I can push it either direction since it hits on both sides. I will probably try to trim or grind the metal down on these spots hoping to get some clearance.
that is really the main problem besides the fact that I still have no idea how this a/c bracket is supposed to work...This product is too generic if you ask me but...hey..i guess thats how they do it for chevrolet products.
Posted: Thu Nov 08, 2007 7:28 pm Post subject: hey..i guess thats how they do it for chevrolet products.
Take some pics. It's not how they do it for Chevrolet products. You did buy low cost parts. I am very curious as they are stated as fitting and I have bought Blackjack in the past (23 years).
Necoa #: 9163
Posted: Thu Nov 08, 2007 8:58 pm Post subject: Re: hey..i guess thats how they do it for chevrolet products
thats true, and I wasnt expecting perfection but if im gonna get a rattly exhaust thats going to kiss me off. I will take some pictures tomorrow. I am fairly sure im going to have to grind something though because its just not happening. They suggest buying new motor mounts...why? it said it about 3 times in the instructions...is this in hopes that your motor wont move the milimeter of clearance they give you and beat their headers against your firewall/underbody?
Necoa #: 9163
Posted: Fri Nov 09, 2007 6:32 pm Post subject: need help
alright......i've been working on it all day. Its pretty frusterating spending so much time to fit the smallest things back in place. The dipstick and spark plugs were realll fun. Is it okay that the wires are practically touching the header tubes?
okay the headers seem to clear everything decently after bolting them up tight, at least the passenger side does. I have that side wrapped up and now I'm working on the driver side where i've encountered a problem. The oil pressure sending unit (i believe thats what it is) it looks like this..
I had to remove it to put the headers in but I forgot where it goes. I look in the general area I pulled it from and I see 2 holes that are threaded. One of them is accessible and appears that it would be clear of the headers but as I've tried to screw it in for like 20 minutes and looked at the threads they seem to be different....which might explain why its not threading in there. So i started second guessing and thinking it was the lower hole but it is very very low on the block above a flange and is completely blocked by the headers.
here is a picture of the UPPER bolt
If this thing can not be mounted (i need confirmation on what these holes are for) then I need to probably plug these holes...and live without the pressure gauge working. any advice on this???? kinda bummed right now, i wanted ot hear this thing run tonight..
Necoa #: 9163
Posted: Fri Nov 09, 2007 10:21 pm Post subject:
okay i got some information from gbody forums. they respond very quickly over there.
apparently the lower bolt hole is the one and I'm going to need to plug it because there's no room to mount this oil unit.
I'm going to use the one on the back of the intake manifold for the gauge. i still need to figure out what that connection goes to though (coming off the intake manifold oil unit)
