El Camino Central :: View topic - 5th Gen multi piston vs stock single caliper
Redster
Necoa #: 7055
PostPosted: Tue Mar 04, 2008 7:45 pm    Post subject: 5th Gen multi piston vs stock single caliper Reply with quote
OK tech/cost evaluation of the options for using a wilwood or similar caliper upgrade for the front discs. We all know that the multi piston has more stopping power but at what cost; as in what all must be done to accomodate the changeover. I am at that crossroad ... got new x-drilled slotted rotors and was going back stock caliper, but couldn't resist getting ECC advice before I act. Whatchya think? Cool
the RED one
MEvang
Necoa #: 7317
PostPosted: Mon Mar 10, 2008 7:44 pm    Post subject: Reply with quote
Here are some things that most people won't consider. Wilwoods like most 4 piston calipers are fixed, therefore your brakes will be more sensitive to lateral runout then a single piston (floating caliper) general where a floating caliper can tolerant .006-.008 runout and fixed caliper (which utilizes a larger pad) will pulsate the pedal at as little as .004-.002 runout. Not so technical, simply you can get a pulsation much easier.
Another thing to consider is most Wilwood 4 piston calipers are not weather sealed. Meaning they have no real dust boots. This means they have a short life in rain snow and mud, so if it's an everyday driver consider this.
On the other hand the Delco Moraine single piston caliper is one of the best calipers ever made, second only to it's larger cousin used on older GM's and trucks for many years. These units are very durable, have a great dust seal and last a long, long time without trouble. You can't beat these units for reliability.
The only thing that can be troublesome is crosion on the exposed slide pins. But buy new ones and coat them with silicon brake grease and they won't be a problem.
But the best thing is, parts are cheap, plentiful, and you can buy them any were. One thing that will never happen with a Wilwood.
If you want more stopping power consider using the older larger Delco calipers. I believe there is a way to use older spindles and someone here has covered this here.
Mike
Redster
Necoa #: 7055
PostPosted: Sat Mar 15, 2008 9:34 am    Post subject: Reply with quote
Mike,
Thanx for the great tech advice/info. This was exactly what I had hoped for in response (though more technically supported than anticipated). You are right, I had not considered the run-out consequences of the obviously tighter tolerences with multi-pistons. Since the 'mino' will be all new on the brakes (front and rear), I am not overly concerned about its ability to stop. It will be likely driven almost daily, thus the importance of durability and anti-pulsating effects. Again, you provided excellent feedback which will directly contibute to this build. Hail 2
Thanx,
Red
the RED one
MEvang
Necoa #: 7317
PostPosted: Wed Mar 19, 2008 6:18 am    Post subject: Reply with quote
I just overhauled the brakes on my '86 and it simply got everything new or rebuilt. The only modification, if you can call it that is I substituted the rear drums for a set of aluminum fined drum I had stowed away. Rare thing they used on some '78 Monta Carlo's and 3rd Gen Camaro's.
Mike
Redster
Necoa #: 7055
PostPosted: Fri Mar 21, 2008 8:07 pm    Post subject: Reply with quote
Mike,
I am thinking with a complete overhaul and going back stock, it will give you solid stopping power. I have seen alum. drums but wasn't sure whether they paid dividends or not. Unless I horse trade for a pair along the line, I plan to go back w/the orig. steel. That is of course unless I get some feedback that I am missing out some real economic performance. Let me know how they are working for you. Cool
the RED one
amp88fan
Necoa #: 11622
PostPosted: Wed May 21, 2008 1:26 pm    Post subject: Reply with quote
i recently aquired my 78' and plan on doin a full restoration on it, but want to drive and enjoy it while doing so....one of my first task is the brakes...i had looked at several diff kits to convert my rear drums to disc and upgrade the fronts to larger rotors and multi piston calipers,etc...but after seeing what this can cost i have came to the conclusions that..for one my budget wont allow it...and two...if i replace the brakes all the way around it..drums, rotors,calipers,hardware,new backing plates,master cyl,booster,and lines...all of witch is allways in stack at my local autozone...i will have less than 500.00 bucks in it all and i am confident that they will provide sufficant stopping power and i can prep and paint the parts before installing for a great looking setup!
78' EL CAMINO SS(mine)
84' OLDS CUTLUSS CALAIS(the wifes)
MEvang
Necoa #: 7317
PostPosted: Wed May 21, 2008 9:01 pm    Post subject: Reply with quote
Here's some advice. Power boosters rarely go bad. If it works let it alone. Same with the master cylinder, if it's not leaking from the rear seal, and if it appears to be the original leave it. If you can confirm it is remanufactured unit replace it with a new unit only. Rebuilt masters are a big waist of money, they rarely last long and are usually a time bomb waiting to go off.
Brake lines and hoses on older cars are of no value, replace them all. There is no reason to mess with them they are cheap, replacing them can save many headaches. Same with parking brake cables, the front rarely goes bad, but the rears are usually a lost cause.
You are right on the backing plates. GM in their infinite wisdom made these backing plates very thin as their vehicles were on a serious diet in 1978. These backing plates were known to wear through or rust out. Another item that got trimmed was the wheel cylinders, the bolts disappeared and a chip ring was used in a D shaped hole in the backing plate. These wheel cylinder were known to twist in the hole and blow out. A good replacement should come with a new clip and have a prongs cast into it to center it on the arbor and keep it from twisting.
Up front replace the wheel bearings. If they have over a 100K it's time for new ones. Rotors and drum can be reused as long as they are with in machine too specifications. But check the rotors careful sometimes on older cars the fins can rust away from the inside. So if they look real rusty you may be better off replacing.
Calipers are inexpensive remanufactured, but be careful. Cores are getting bad, look for bent ears (where the pins go through) bleeder repair kits, excessively rust pitted housings, and pistons that appear to have been sand blasts and painted. Reject them if you find any of this. Replace the slide pins. These are important and rusty ones don't work well. These cars came with metallic pads. Your better off with metallic then carbon fiber in most cases.
Finally use a good synthetic brake fluid. Do not use silicon fluids. The synthetics are far more superior.
Follow these steps and you'll save money and lots of aggravation.
Mike
amp88fan
Necoa #: 11622
PostPosted: Wed May 21, 2008 10:33 pm    Post subject: Reply with quote
thanks for the detailed info on refurbishing the brakes....so i had planned to replace the m/c and booster....you say it should be fine?....and you mentioned some hassels....excactly what kind of hassles are we talkin here? to replace the m/c and booster,if i am replacing everything else anyway? i have worked on many brakes front and rear but have never swapped out a m/c or brake booster before....dont get me wrong i know you must bench bleed the m/c but what does it take to get the booster swapped out?
MEvang
Necoa #: 7317
PostPosted: Thu May 22, 2008 8:58 pm    Post subject: Reply with quote
Not really any hassles replacing them, the problem comes with rebuilt units and this is what you are going to find. Many times they are not as good as a working original unit. If you want to replace the master cylinder, just make sure you get a new unit. Raybestos and Napa make good new unit but also make rebuilt's so make sure you specify new. Auto Zone likely only carry rebuilt's.
But my opinion is if the booster is working stay with the original, they don't wear out and rarely fail so I see no reason to replace it.
Mike
amp88fan
Necoa #: 11622
PostPosted: Thu May 22, 2008 11:00 pm    Post subject: Reply with quote
Mike
well the reason i am wanting to replace the stock m/c and booster has a lot to do with the fact that they are very rusted...i really dont know if the brakes even work all that well at all to tell ya the truth...it has not moved since i bought it...i am waiting on a trans,torque con,trans cooler, along with a butt load of other things....but i had figured on replacing the brake system pretty much completly back to stock with new parts....above you stated that replcing the booster or m/c with rebuilt parts is a no-no! but if i replace both with NEW stock units i shoud be good right? or are you saying the old rust stock one is goona work just as good...or bettr????
MEvang
Necoa #: 7317
PostPosted: Fri May 23, 2008 6:24 am    Post subject: Reply with quote
You may find NOS parts but that might be a stretch. As I said aftermarket company like Raybestos do produce new master cylinders which are very reliable. Booster on the other hand are always rebuilds.
I have used Cardone a lot for rebuilt ABS parts. They also supply power brake boosters. I was always happy with their quality. But take note, many rebuilders sell booster with master cylinders. These masters are always cheap rebuilds. If you buy one like this just toss the master and get a new one.
Another alternative is to buy a good used booster and you can always upgrade to new model boosters that tend to give better braking.
While your checking salvage yards another upgrade you should consider is a swap to '80 up spindles. 1978 used a smaller outter wheel bearing and a one year off rotor. If you get spindle from a '80 up Malibu, Monta Carlos, El Camino or any other intermediate GM use will get the benefit of the better wheel bearings and a much more plentiful rotor which is likely cheaper to buy new.
Lastly if stuff is rusty the front rotor backing plates shields are still available from GM for about 20 bucks each. Part numbers 459757 SHLD ASM and 459758 SHLD ASSM.
Mike
amp88fan
Necoa #: 11622
PostPosted: Fri May 23, 2008 9:25 am    Post subject: Reply with quote
ok here is the new m/c i plan on getting....
http://www.autozone.com/R,APP15092/vehicleId,1301204/initialAction,partProductDetail/store,693/partType,00007/shopping/partProductDetail.htm
now my car has a duel diafram booster...can that be replaced by a single diafram for better clearance or must i go with the deul?.....
and if i get a rebuilt cardone booster with the new m/c...i should be ok?
http://www.autozone.com/N,14400143//shopping/partTypeResultSet.htm
amp88fan
Necoa #: 11622
PostPosted: Fri May 23, 2008 10:27 am    Post subject: Reply with quote
i would like to find a complete kit to replace my brakes....i would love to convert the rears to disc...i am on a budget of about 1200.00 but i cant find anyone who sells the complete set for my 78'
amp88fan
Necoa #: 11622
PostPosted: Fri May 23, 2008 5:56 pm    Post subject: Reply with quote
Mike
where can i get these backing sheilds for the front....autozone has the plates for the rear drums....but they dont carry the split plate...this means i will have to take out the axl to install them right? do you know whaere i can get the split plates with the cylinders ? and now that i think about this more it is starting to sound like for a few more hundo's i could just do the rear drum conversion and get a kit with everything....
MEvang
Necoa #: 7317
PostPosted: Sat May 24, 2008 7:34 am    Post subject: Reply with quote
The numbers and price I gave you are GM numbers, go to your local Chevy dealer and they can get them. Split rear backing plates were popular about 10 years ago but I have seen them around for a while. Domain or Motor Mite may have them. If you can't find them and need them IM me I have a pair.
IF your hot on rear disc brakes I recommend the late S10 brakes. Mater of fact I have a request in to my buddy that owns a salvage yard to be on the look out for a donor for me.
About your Auto Zone master cylinder Fenco is a Canadian company that claims to be an OEM supplier to Ford. I have no experience with their products so I can't recommend them. They may be good I just don't know.
Mike
Page Generation: 0.379 Seconds
