El Camino Central :: View topic - Torque conveerter lockup question.
Midnight87
Necoa #: 11095
PostPosted: Sun Mar 16, 2008 5:58 pm    Post subject: Torque conveerter lockup question. Reply with quote
"87 EC with 305 and metric 200 trans. The torque converter keep locking and unlocking while out on the highway. This is constant on/off situation. Any ideas what can be causing this? The only changes from stock is that the air pump was frozen so I took off the associated smog equipment. Distributor and carb are still computer controlled.
PostPosted: Sun Mar 16, 2008 9:11 pm    Post subject: Reply with quote
I can't believe GM was using that POS transmission in '87. I had that in my '85 and after the second time it crapped out I had a TH350 put in. Don't spend any money on a metric 200. That is a light duty trans and it has no business behind a V8 even a 305. You can have a rebuilt TH350 trans installed for about the same price as overhauling a metric 200.
A TH350 trans works real good with a 2.41 real axle ratio and will replace a metric 200 without any mods.
Midnight87
Necoa #: 11095
PostPosted: Sun Mar 16, 2008 9:31 pm    Post subject: Reply with quote
You are so right. I am very aware of the 200's reputation. This particular trans was rebuilt last year by the previous owner but that means nothing. I have a 700R4 ready to go in already. What I need to know is why is the converter locking/unlocking all the time, if it's a problem with the ECM then it's hitting the trash barrel too. If it's just the trans then I will be rid of it soon.
PostPosted: Sun Mar 16, 2008 10:35 pm    Post subject: Reply with quote
Since the converter locks up part of the time, I doubt the computer is the problem. Even if it is you can wire around it with a kit from Bowtie Overdrives. Link
http://www.bowtieoverdrives.com/catalog/catalog.php?Action=GETSUBCAT&CATID=OA1
PostPosted: Mon Mar 17, 2008 4:22 am    Post subject: Reply with quote
If it's an 87 it's probably has a 200-4r transmission, which is a good transmission. The ECM controls the torque convertor lockup. First, you need a scanner to see what the ECM is doing. It may be something as simple as the TCC unlock switch on the brake pedal or the 4th gear pressure switch.
PostPosted: Mon Mar 17, 2008 8:43 am    Post subject: Reply with quote
Hey Ernie, does a 200-4R trans have "metric" embossed on the pan like a 200 metric?
Midnight87
Necoa #: 11095
PostPosted: Mon Mar 17, 2008 9:10 am    Post subject: Reply with quote
It is definitely a metric 200, there is no overdrive. Also the gear indicator is only for a 3 speed. I am changing all this so what is in there is a moot point. All I need to know is if the constant lock/unlock problem is trans related or computer related. I will be removing all trans related possibilities but I need to know if the computer could possibly be acting up causing this problem. If it is, then I will have to replace or do away with the computer. I have a scanner, albeit not a real good one, all it showed was a faulty EGR code.
PostPosted: Mon Mar 17, 2008 6:37 pm    Post subject: Reply with quote
Yes Doug. It says "METRIC" in caps on the bottom driver side of the pan. It also says "Hydra-matic".
bigdave396
Necoa #: 11320
PostPosted: Wed Mar 26, 2008 11:57 am    Post subject: Reply with quote
Could also be the convertor too. But the computer needs to be checked to see if the ecm is telling the lock up solenoid to turn off and on. Or the solenoid its self.
Midnight87
Necoa #: 11095
PostPosted: Wed Mar 26, 2008 12:24 pm    Post subject: Reply with quote
Thanks bigdave, I had a trans expert tell me almost the same thing except he didn't feel the computer was the problem. It doesn't matter the trans and the computer are both coming out of the car soon.
elcamman006
Necoa #: 10766
PostPosted: Thu Mar 27, 2008 1:11 am    Post subject: Reply with quote
what does it do when the conver stops?
Midnight87
Necoa #: 11095
PostPosted: Thu Mar 27, 2008 8:12 am    Post subject: Reply with quote
Engine speed drops or climbs 300-400 rpm when it locks or unlocks.
bigdave396
Necoa #: 11320
PostPosted: Thu Mar 27, 2008 12:38 pm    Post subject: Reply with quote
your welcome man i used to work for a tranny shop. so i hope it helped you out.
bigdave396
Necoa #: 11320
PostPosted: Thu Mar 27, 2008 12:41 pm    Post subject: Reply with quote
it would not move if the convertor goes out completly its like the clutch tha connects the engine to the trans. it has controlled slippage inside.
spoonplugger
Necoa #: 1271
PostPosted: Fri Apr 04, 2008 11:03 pm    Post subject: Reply with quote
This response is a little late, but better than never. Right? I had the same problem and found the problem was a faulty Throttle position Sensor (TPS). Apparently, the rheostat had a bad spot in the coil. The TPS is located in the electronic carburretor. About $26.00 from Auto Zone, if memory serves me correctly. Before you replace it, be sure you know how to adjst the voltage and make sure you have the adjsuting tool in hand, otherwise, it's a pain in the butt.
86 caballero, 350 cid, TH350C
Page Generation: 0.386 Seconds
