El Camino Central :: View topic - all bad!! any opinions??
elcamman006
Necoa #: 10766
PostPosted: Wed Apr 09, 2008 11:23 am    Post subject: all bad!! any opinions?? Reply with quote
i have a 69 with a th400 and a crate 350 and my flywheel was stripped out so it was making the grinding noise so i dropped the tranny and changed the starter and flywheel the guy at my local part store said that there was only 1 starter for the 350 so i got that and then i got the flywheel to match the old one.. i put it all together and it started up perfect when i was driveing it it was makeing a rattling noise toward the passinger side so i switech to bitch and let my girl drive so i could hear it, it was just a metal hose banging against the firewall.. so i moved it and when my gf started it up it did that same old grinding noise again!!! Sad i dont know what to do all that work for nothing!!! what could it be
80blacky
Necoa #: 9998
PostPosted: Wed Apr 09, 2008 1:01 pm    Post subject: Reply with quote
The knurling on the starter bolts could be worn out, making the starter wobble and move all over the place when cranking. I found out the hard way and went through like 4 starters before I figured it out. New bolts cured the problem.
PostPosted: Wed Apr 09, 2008 5:42 pm    Post subject: Reply with quote
You may need to shim the starter to get the correct gear mesh between the starter and flexplate. Autos dont have flywheels.
elcamman006
Necoa #: 10766
PostPosted: Wed Apr 09, 2008 10:57 pm    Post subject: Reply with quote
i have new bolts and they are hella tight!! and i also tried shimming it said to be able to fit a 1/8 drill bit snug between the gears and i did that and it was still doing it so i even shimmed till i couldnt fit the bit in
PostPosted: Wed Apr 09, 2008 11:42 pm    Post subject: Reply with quote
If you have it shimed that much its too tight. Not sure why it did it before.
bigdave396
Necoa #: 11320
PostPosted: Thu Apr 10, 2008 10:13 am    Post subject: Reply with quote
could be off base here but i had a bronco that the dowl holes in the bell housing got wore out and i had trouble keeping a starter on it. i changed the bell housing and it cure my problem. if im not mistaken there are wo different flexplates 1 small block and 1 big block. but agian i may be off track here. just offering suggestions.
elcamman006
Necoa #: 10766
PostPosted: Thu Apr 10, 2008 10:40 am    Post subject: Reply with quote
well the wholes where i mound the starter aren't on the bell houseing i dont think there are any wholes on the bell houseing?? but ill try to lessen the shims on one side and then try different combos.. idk what else to do my starter seems tight and im prety sure i put the flexplate back on in the correct direction
RK-Carsen
Necoa #: 4647
PostPosted: Thu Apr 10, 2008 12:44 pm    Post subject: Reply with quote
I once had the bolts connecting my flexplate to the torque convertor come loose. Gave me a bad grinding noise when it tried to start it.
'78 El Camino
'79 El Camino Royal Knight
'80 El Camino
'86 Yamaha FZ700
elcamman006
Necoa #: 10766
PostPosted: Thu Apr 10, 2008 6:40 pm    Post subject: Reply with quote
i just dropped the tranny and did all that stuff so i think i tightened it pretty good
el meenoo
Necoa #: 11394
PostPosted: Sat Apr 12, 2008 6:10 pm    Post subject: Reply with quote
just my two cents worth. had a 350 not sure of what year went through 4 starter motors they are all a little different!! bought a gear reduction starter(mini)...end of problem...
Still spending money I dont have on car parts
elcamman006
Necoa #: 10766
PostPosted: Sun Apr 13, 2008 3:32 am    Post subject: Reply with quote
yup that was the problem i just figured it out then i read ur message lol thanks for everyones help
Page Generation: 0.330 Seconds
