Necoa #: 3820
Posted: Mon Apr 21, 2008 8:56 pm Post subject: WtB a two barrel Rochester Quadra-jet manual choke
looking to buy one within the next month.mine died over winter and i am starting to restore the elky back to stock.. in working order would be great. if u have one throw some prices at me this is gonna be my b-day present from the wife . _________________
Does it have to be a manual choke? I have a few Qjets but all are electric choke. _________________ Jeff J
70 El Camino long time resto
81 Monte Carlo
86 El Camino 4.3 TBI
Many more A/G bodys
The only manual chokes would be a conversion kit has been put on it. _________________ 84 Elky with 455 Buick, Tremec TKO600 5 speed, 8.5 3:42 posi -
Necoa #: 3820
Posted: Mon May 19, 2008 3:12 am Post subject:
thanks for the replies guys, how hard would it be hooking up a electric choke I'm pretty sure it would be easy but i never had a problem wit the original until this past year after i took it out of storage it for about 9 months without starting. I'm gonna check the local advance auto and see what they have for sale. if not i might send it out for a rebuild. _________________
Necoa #: 9715
Posted: Mon May 26, 2008 10:36 pm Post subject:
electric choke is VERY simple all you have to do is run the wire to the fuse panel to the IGN port in it
it's cake walk
also i have a 1974 2bbl rochester carb it is good and complete, it has the hot air vacuum tube type automatic choke, if you have the spot in the pass side center of the intake at the number 4 and 6 cylinders with two small threaded bolt holes in the intake to mount the heat vacuum tube plate deal to it then it will work
good luck _________________ Randy
Lincoln IL
'85 Elky SS new black and silver paint, brand new dash/carpet/door panels/headliner/weatherstripping/seat; fresh original LG4 305 .030" over; 2004R; 2.73 7.5"; stock 14" rallies
