Necoa #: 11255
Year: 1968
Posted: Sat
May 10, 2008 2:29
pm Post subject: LS1 Fuel pump in 68 ECamino
Hi Guys,
Me again from sunny England with another problem. I am putting an LS1 from a 98 Camaro in my 68 Camino. I took the Camaro fuel tank and pump but cannot see how they can be used. Can I run this pump externally doing away with the sock and connecting this direct to my Camino fuel line. There are 4 pipes from the Camaro pump 1 fuel line 1 fuel return but what are the other 2 ? Would it not be easier to run an aftermarket pump like a Aeromotive and put a reurn line back into the original tank. Any opinions greatly appreciated.
KEV _________________ 68 EL CAMINO MALIBU. 69 AUSTIN A60 PICKUP RACE CAR WITH 427 SBC WITH PROCHARGER RUNNING 9.2 SEC 1/4 MILE
Most people use an external pump. A few have used the camaro pump's by retrofitting the old tank. basically they weld and fab the tank to accept the newer pump. Still others have used the camaro tank and pump, simply made the body and chassi work with it. The best way to do it is to make the old tank work with the camaro pump. the cheapest way to do it is to just use an external pump with a corvette regulator or other aftermarket regulator. _________________ 1980 El Camino
2002 LS1, 4L60e swap
345hp, and 23 mpg.
