Posted: Fri May 23, 2008 5:36 pm Post subject:
It will work for 78 t0 87 years with Auto 350 or PowerGlide or 200r4 Trans. as the 200r4 is mostly a direct bolt in replacement upgrade to the 350. The specs say nothing about the th200, so there may be modifacations that may have to be done to make it work. Someone else may chime in and be more specific. _________________ http://elcaminocentral.com/gallery-album_CoyoteOn2s77Cage.html
Necoa #: 9990
Posted: Fri May 23, 2008 7:06 pm Post subject:
I used the G Force Performance RC350 crossmember and I was very happy with the way it fit and the clearance that it gave for the exhaust.
The sumit crossmember looks very much like the G Force.
RC350 Crossmember will fit all 1978 thru 1988 G-Body cars with a TH350, TH200, Powerglide, Saginaw, T-10, Super T-10, or Muncie Transmission.
