El Camino Central :: View topic - LS1 Engine installation in 87 El Camino Conquisa -- HELP
BuckeyeDave
Necoa #: 11030
PostPosted: Sat May 24, 2008 5:18 pm    Post subject: LS1 Engine installation in 87 El Camino Conquisa -- HELP Reply with quote
Will a Chevy LS1 engine fit in a 1987 El Camino Conquista without making modifications? Would appreciate hearing from anyone who has experience in this area.
greywolf
Necoa #: 64
PostPosted: Sun May 25, 2008 11:04 pm    Post subject: Reply with quote
You'll need to notch the front cross member to clear the oil pan. That's been done before, check other LS1 threads in this forum for info.
Also you'll need high pressure fuel pump and return line from the pressure regulator.
And you need to figure out how to supply power to the computer, and where to mount it. Computers are sensitive to voltage, so I used the ignition switch to control a relay to feed the computer instead of feeding it straight from the ignition switch.
I don't recall seeing anything in this forum about a radiator fan, but you'll need an electric one since the LS1 doesn't have a fan belt.
That's the main stuff, then there are a bunch of smaller bits. Browse the forum for info. Also try Ls1.com web site.
PostPosted: Tue May 27, 2008 5:29 pm    Post subject: Reply with quote
it may be possible to swap wiothout cutting the xmember. there are some production pans out there that may work. I know for a fact the alpha 5.3 Hummer pan works on s10's.
try ls1tech.com and hit up "g-body". I'm over there too.
edit: just to avoid confusion g-body is not me, I use this name.
Andreas
Necoa #: 8487
PostPosted: Wed May 28, 2008 2:24 pm    Post subject: Reply with quote
caddy cts-v pan ....try lstech.com
juced211s
Necoa #: 12147
PostPosted: Sun Jul 20, 2008 8:55 pm    Post subject: Reply with quote
I believe that some of the LS setups used a self regulated pump so there was no need for a return line. Not sure if they are interchangable though. I have also read of nightmares with getting the factory accessories to clear the frame, I guess it depends what vehicle the engine is coming out of. Definitely would be a cool swap though.
Jon
www.LT1Conversion.com
EL S ONE
Necoa #: 10110
PostPosted: Sun Nov 09, 2008 6:07 pm    Post subject: LS1 into Elcmanio Reply with quote
Go to John Bzdel's site. http://home.earthlink.net/~bzdel/ I bought his motor mounts and oilpan mod. He proved his work by drag racing his engine change.I did notch the cross member so i could run the air con pump in its stock acessory drive location.I went with a Corvette fuel filter/pressure regulator so a short return is required.
Original owner. "04" LS1. 4L60E. GN 8.5 3.73's. Eaton posi. Dual 2.5 Tubes & Flowmaster 50's. Electric antenna. C.A.R.B approved.
Page Generation: 0.310 Seconds
