El Camino Central :: View topic - Float Bowl going dry
JimIsbell
Necoa #: 8721
PostPosted: Sun May 25, 2008 5:56 pm    Post subject: Float Bowl going dry Reply with quote
On my 1983 EC with 229 V6 and Dual Jet carb I am having a problem that is frustrating and wasteful of fuel.
When the car sits for 48 hours it is very hard to start and takes a lot of cranking and kicking the gas pedal to inject fuel into the system. And I am talking about night time temperatures in the LOW 80s and day time temps of 95F, so its not cold. I have tracked this down to the fact that after 24 to 48 hours the float bowl is dry, ( I opened the carb to look!) thus requiring the fuel pump to fill it again before it will start.
The bowl is vented through a brass pipe about the size of my little finger and is also vented through the space (clearance) between the accelerator pump shaft and the top of the carb. It would seem this latter vent should be enough to pressure equalise the bowl without that huge stove pipe through which all my fuel can evaporate.
What would be the effect if I were to plug that large vent pipe?
Jim
1983 El Camino
PostPosted: Sun May 25, 2008 8:25 pm    Post subject: Reply with quote
Jim, That would be unknown to me. But a little experiment wouldn't do any harm. Take a peace of rubber tubbing of sorts that will go over that vent, block off the open end, run the car for a while, then drive the car a bit and see if you notice any adverse effects. If not, then park the car for that 24 hour period, then check if will then start for you of if the same prob. re-occurs. That will give you something to go on in your future evaluation. Hope this helps, thing like that can be so frustrating.
JimIsbell
Necoa #: 8721
PostPosted: Sun May 25, 2008 9:36 pm    Post subject: Reply with quote
I was planing on doing just that tomorrow. I will let you know how it comes out.
I noticed your sig line. I take it you were in racing? I was in Formula racing. Our moto was "Race?... Hell, we're just here for the cocktail party." I drove an FF and FA for two years.
Jim
1983 El Camino
PostPosted: Sun May 25, 2008 9:47 pm    Post subject: Reply with quote
Jim, it sounds like you have a leak in one of the fuel-well plugs. It's a common problem with Rochester carburetors. The fuel in the bowl will leak down into the intake over a period of time. If that is the case the only way you can fix it is by opening up the carb and sealing them all with epoxy.
Let us know how it goes, and take photos if you can and post them.
And yes in my younger years, now it's just the memories.
PostPosted: Sun May 25, 2008 9:55 pm    Post subject: Reply with quote
Jim, as Ernie said, I forgot about those four plugs. Back in the day, (Ernie maybe you know this trick also) we use to cut a chunk off an old wheel weight, (lead) and punch it in the plug holes with a drift punch and re-seal them that way. But that was before Epoxy & you didn't have to wait for it to dry.
PostPosted: Mon May 26, 2008 9:24 am    Post subject: Reply with quote
Jim
Here is some info from a post I wrote a while back that I found. By small wire brush, I mean something like a copper fitting cleaning brush.
"The other problem q-jets have that make them run rich is the two plugs in the base of the float bowl begin to leak. These can be accessed by removing the base from the bowl. Kits come with a small triangular shaped foam piece to lay in the base to apply upward pressure to the plugs. This alone won't last long. Use a small wire brush and totally clean the plugs and the small area of aluminum around them. Use a heat gun or something similar and warm them to the point they are just too hot to touch and then apply a light coat of epoxy(heating them lets the epoxy penetrate around them and set up quicker). Let that cure, install the foam and reinstall the base. This fix is usually good for about 10 years and has to be done again"
If you don't have the foam don't worry it is just added insurance. If you try to make something, test it first to make sure gasoline doesn't eat it.
You have probably found by now that if you plug the vent it will starve for fuel under acceleration. Evaporation out the bowl vent is not the problem. If you have that much clearance around the pump shaft that you think the bowl will vent there - the bowl cover is worn out.
CANTED
PostPosted: Mon May 26, 2008 9:38 am    Post subject: leaking casting plugs Reply with quote
The plugs in my car have been leaking for a while and that has been on my to do list. I have read about a more permanent fix though. The story goes that NAPA has a kit with O ringed plugs. You drive out the old ones, clean up the holes and press in the new ones, end of leak.
Jim
JimIsbell
Necoa #: 8721
PostPosted: Mon May 26, 2008 10:14 am    Post subject: Reply with quote
Just what is the purpose of plugged holes in the first place....just to make something the mechanics can feed their family's with? Why wasnt it made solid to start with?
Jim
1983 El Camino
JimIsbell
Necoa #: 8721
PostPosted: Mon May 26, 2008 10:19 am    Post subject: Reply with quote
Larry,
it was in my younger days as well, but I have more than memories....I have a Lola FF/FA stored away in the garage in case I ever want to try it again. I should sell it though as I need the room for my other projects.
Jim
1983 El Camino
PostPosted: Mon May 26, 2008 4:37 pm    Post subject: Reply with quote
The purpose of the plugged holes was to allow them to drill the fuel passages in the bowl. Necessary evil.
I like the idea of the o-ringed ones though. I'll have to check that out.
JimIsbell
Necoa #: 8721
PostPosted: Mon May 26, 2008 4:45 pm    Post subject: Reply with quote
Can you see the plugs from above? I looked into the bown and see onl,y the two jets that the metering rods fit into. I dont see any other plugs in the bowl except for one screw at the front. Not sure what that is.
Jim
1983 El Camino
PostPosted: Mon May 26, 2008 4:58 pm    Post subject: Reply with quote
Jim, you have to remove the top of the carb, they are located in the bottom of the float bowl
JimIsbell
Necoa #: 8721
PostPosted: Mon May 26, 2008 5:10 pm    Post subject: Reply with quote
Yes, I understand that. I removed the top and looked down into the bowl. There are two jets toward the front into which the metering rods go and there is a screw a bit forward of that, but no "plugs"
Jim
1983 El Camino
PostPosted: Mon May 26, 2008 5:43 pm    Post subject: Reply with quote
464elky wrote:
Jim
Sorry, should have been a little clearer. 464elky had already mentioned about the base removal
Page Generation: 0.385 Seconds
