El Camino Central :: View topic - I need a power source
diesel camino
Necoa #: 9618
PostPosted: Thu Jun 12, 2008 8:37 am    Post subject: I need a power source Reply with quote
I am shaving the door handles on my elky. I got a kit from Autoloc but the directions are a little sketchy. I have a pretty good wiring diagram but I'm not sure what gage of wire I need to run to the actuator and I'm not sure where I should go for a power source. I need a constant hot that will power the actuator itself and I also need a switch on hot for the safty circut. I was thinking about putting in an add on fuse panel but I'm still not sure where to get the power from for that or if it is even needed.
I am pretty good with body work and intierior work but the electrical stuff kind of scares me. Any help would be appreciated.
Steve
yes it really does have a diesel engine
PostPosted: Thu Jun 12, 2008 9:53 am    Post subject: Reply with quote
Steve, More Info is needed to answer your question. (NEED to know the required amps needed to opperate your actuator's to determine the min. wire size / fuse size) But yes, you should, or better, be sure that a fuse IS used on the power supply wires.
diesel camino
Necoa #: 9618
PostPosted: Thu Jun 12, 2008 9:37 pm    Post subject: Reply with quote
CoyoteOn2 wrote:
Steve, More Info is needed to answer your question. (NEED to know the required amps needed to opperate your actuator's to determine the min. wire size / fuse size) .
Here lies the problem. No were in the instructions does it say how many amps these things draw. The actuators are Autoloc 45lb units. If anyone out there knows how many amps these things pull. I'm sure there is a way to test them but I'm not sure how.
Steve
PostPosted: Fri Jun 13, 2008 2:43 am    Post subject: Reply with quote
Steve, with the 45# door poppers you should be ok with a 14 gauge wire, they only draw current for 1 to 2 sec. I would try and use a 15 amp fuse to start with, but you may have to jump up to a 20. If memory serves me right, I beleave the 45 pounders have a max rateing of 30 amps.
AND I JUST HATE YELLOW~~~EVEN IF IT AIN'T A SUBMERINE
diesel camino
Necoa #: 9618
PostPosted: Fri Jun 13, 2008 7:57 am    Post subject: Reply with quote
Thanx for the info on wire gauges and amps. I have pretty much decided to get the add on fuse panel from painless. Were would be a good place to hook into the system for this. Should I just hook into the power at the starter?
PostPosted: Fri Jun 13, 2008 10:06 am    Post subject: Reply with quote
That's perfect! And It's Main feed wire, (the new box) will most likely be a fussed one with a large Jumbo 30 /40 / 50 amp fuse. It will also come with very good Instructions. You will be pleased with your choice.
