El Camino Central :: View topic - engine wont start no crank
79ElkyFl
Necoa #: 11858
PostPosted: Fri Jun 13, 2008 10:17 pm    Post subject: engine wont start no crank Reply with quote
I was changing a vaulve cove gasket and when I removed it I disconected the alternator.I accidently forgot to reconnect the wires to the alternator and eventual when the batt died the car no longer ran.So I charged the battery and started up the car I let it run for about 5 minutes then turned it off.When I tried to start it again it would not start no crank nothing.I took the battery out again and fully charged it and same result the car started and ran untill I turned it off the would not restart.any thoughts on a quick fix would be nice and yes I check that the gound wires are tight.
PostPosted: Fri Jun 13, 2008 11:18 pm    Post subject: Reply with quote
It is possiable that just by coincedence that your Batt. has come to the end of it's life span, or your Alt, same senario. Take the Batt. and Alt. to your local AutoZone for load testing. If all your connections are good, and fusses are good, thats where I'd begin. Not real sure if your Alt. Batt. wire has a fussable link or not. (Not likely)You can Ohm it out to see if it is compleating a circut
79ElkyFl
Necoa #: 11858
PostPosted: Sat Jun 14, 2008 8:55 am    Post subject: no start Reply with quote
I have power to the headlights and the aftermarket radio deck so I dont think it is the batt.would the alternator being bad stop the car from getting power to the starter because it will not even crank it is like I have no power to anything.
PostPosted: Sat Jun 14, 2008 11:08 am    Post subject: Reply with quote
Sounds like the fussable link to the Starter Selonoid is blown, Should be a Purple wire. Open the link and see at the bottom of the page the wireing for starter. In that Purple Wire there is a fussable Link, if it is soft or real flexable it is blown and needs to be replaced. NOTE: It is part of the wire, molded in the wire
http://elcaminocentral.com/articles/wiring/811.gif
79ElkyFl
Necoa #: 11858
PostPosted: Sat Jun 14, 2008 11:42 am    Post subject: solution Reply with quote
Thanks for all the help the wires coming from the starter to the dash were worn and melting to the exaust.I rewired everything and ziptied it away from the pipes now everything is working great thanks again for all the help.
