El Camino Central :: View topic - Qjet well plug fix
Qjet well plug fix
CANTED
PostPosted: Sat Jun 28, 2008 10:43 pm    Post subject: Qjet well plug fix Reply with quote
The well plugs had started to leak in my carb. I read about a permanent fix with replacement plugs rather than the glue method. I had a go at that today and took a few pics.
Patient ready for surgery.
This one did not come out good but you drive the roll pin back to release the accel pump lever.
Remove the top screws, don't forget the two by the booster.
Remove the screw holding the choke linkage on.
Topless
Remove the three screws from the bottom
With the bottom off you can access the plugs
The casting is staked around the plugs, you need to file that down.
Ready to remove
You need to make this tool out of some stiff rod. It needs a little dog leg, and the end rounded.
Tool installed in air bleed, tap with hammer, plug pops out. Repeat on the other side.
Plugs out.
Deburr holes with a blade
Well plug kit from Napa, these plugs have O rings to seal them.
Lube with drop of oil and tap into place. The raised points on the new plugs were a bit long and bottomed out in the base keeping it from going together. A few more taps to flatten the points out a bit made room. There is also a foam piece that comes with it that goes in the base under the plugs.
Jim
PostPosted: Sun Jun 29, 2008 10:29 pm    Post subject: Reply with quote
Nice post and info with great pictures.
doug
Page Generation: 0.291 Seconds
