Necoa #: 6535
Posted: Wed Jul 23, 2008 7:26 am Post subject: 78 Elky clutch Fork
Hey folks!
I've been looking for this item for a bit and i haven't been able to find anybody reproducing them. I am in need of a clutch fork for my 78 SS. It has the factory saginaw 4 speed. I am in the process of installing a new clutch pressure plate etc. and the fork has substantial wear. naturally i would like to replace all the worn parts while it is apart. Does anyone know of a place that i could find a new one(doesn't have to be a GM could be aftermarket) or at least one that is in real decent shape used? Any help on this would be greatly appreciated!!
Thanks!
If all that is worn is the tips where it pushes the throwout bearing I have fixed them by building up some weld and then grinding and filing it back to shape. Might be worth a try. sounds like you have nothing to loose. _________________ 84 Elky with 455 Buick, Tremec TKO600 5 speed, 8.5 3:42 posi -
Advance Auto Parts shows that they have the clutch fork for the 78 EL Camino with 350 eng and you can order it online at advanceauto.com but it is pricy at $76.99 the part no. is 14568 good luck _________________ Bigger is always better-406 full roller motor, purpose built 700r4, 373 posi
