El Camino Central :: View topic - Engine swap question
Dumbell
Necoa #: 9685
PostPosted: Sun Oct 05, 2008 1:38 pm    Post subject: Engine swap question Reply with quote
My '69 has a 305 ci engine in it right now, but I was planning on putting a 350 ci from my dad's Camaro in it. Question is, will it hook up to the tranny will no modifications? The tranny is a saginaw 4 speed.
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
PostPosted: Sun Oct 05, 2008 1:48 pm    Post subject: Reply with quote
The bellhousing for the Saginaw should bolt right up to the 350. You'll need to install an input shaft bushing/bearing into the crankshaft of the 350.
Dumbell
Necoa #: 9685
PostPosted: Sun Oct 05, 2008 2:05 pm    Post subject: Reply with quote
Okay thanks. Would that be all it needs?
PostPosted: Sun Oct 05, 2008 3:18 pm    Post subject: Reply with quote
I like that and I almost wanna say sure...but let's be realistic. When your doing a swap you may or may not find things that need to be replaced during the swap...here's a few...motor mounts, transmission mount, clutch disc, pressure plate, throwout bearing, resurface or replace flywheel (is it the right flywheel), exhaust manifold donut gaskets and maybe the bolts...could be a couple of things or a whole slew of things. Bottom line is...sure do the swap...you'll be much happier in the long run and have more pride in your Elky, but don't expect it to be a piece of cake...$#!+ happens, replace the things that need to be replaced during the swap...or you may find that you should have replaced them when you had the chance and now you gotta drop that trans or yank that engine again. DO IT RIGHT THE FIRST TIME!!! I am a little curious how a 305 got in your 69...you sure it's not a 307...not that it matters anyway.
Last edited by theelcaminofactory on Sun Oct 05, 2008 3:24 pm; edited 1 time in total
rtabish
Necoa #: 12454
PostPosted: Sun Oct 05, 2008 3:19 pm    Post subject: Reply with quote
you didn't say what the year was of your dads 350, or if it is from an automatic or manual tranny car, but if it is from the same time frame [+/- 10 years or so], there should be no difference in the back of the blocks.
small block chevies are "PRETTY MUCH" identical on the outside for most of the production run of the engine....something like 1955 to the mid 90s, and you can still buy brand new SBC engines from any number of places. the only differences in the blocks is where the mounting gussets or holes are located for various add-ons [and of course the deck height on some blocks]. this wouldn't have any effect on the tranny mount or engine mounts, which are all the same [there are, of course, exceptions to this, like the older front mount engines and some truck engines].
this would leave only finding a flywheel and pilot bearing for a 350...not the flex plate you have on automatic cars. but like theelcaminofactory said, be prepared for all the incidental little things, too.
Rob Tabish
Missoula, Montana
77 El Camino
83 Toyota Landcruiser
81 Honda CB900F
81 Honda CB900Custom
PostPosted: Sun Oct 05, 2008 3:34 pm    Post subject: Reply with quote
Crankshaft flange diameter could be different, one piece rear main seal motors have the small diameter crankshaft flange, two piece rear main seal motors have the large diameter crankshaft flange...you need to use the corresponding flywheel or the flywheel won't bolt up to the crank....and if you do need to replace the flywheel then you need to get the one with the correct number of starter gear teeth...or then buy another starter motor. Also a newer 350 could be an externally balanced motor and your current motor internally balanced...that could also cause you to buy a new flywheel. If you can post the casting numbers and year of both motors, I might be able to help you avoid some headaches.
Dumbell
Necoa #: 9685
PostPosted: Sun Oct 05, 2008 3:56 pm    Post subject: Reply with quote
Okay here's more info for you guys.
The 305 in it isn't stock. That's pretty much all I know about it.
My dad isn't sure about the 350 either, he just knows it was in his Camaro (1971) when he got it. It was from an automatic car.
PostPosted: Sun Oct 05, 2008 4:18 pm    Post subject: Reply with quote
The year of both cars is not what's important...I doubt that the motor in the 71 Camaro is the original, but it could be...we know your motor isn't the original motor in your Elky. Post the casting numbers and year of both motors. Whatever the outcome, it's not a difficult or expensive match of parts...if you have to do anything at all.
Dumbell
Necoa #: 9685
PostPosted: Sun Oct 19, 2008 4:50 pm    Post subject: Reply with quote
I haven't checked the numbers on the 305, but now I know that both are pre '86 or so since both oil dipsticks are on the right side. So I guess the flywheel on the 305 should work for the 350.
Dumbell
Necoa #: 9685
PostPosted: Mon Oct 20, 2008 4:05 pm    Post subject: Reply with quote
The 305 is from a '79 Camaro and the 350 is from a '71 El Camino.
rtabish
Necoa #: 12454
PostPosted: Mon Oct 20, 2008 4:22 pm    Post subject: Reply with quote
well there you go! must be a sign from the car gods, eh? Happy
Rob Tabish
Missoula, Montana
77 El Camino
81 Honda CB900F
