El Camino Central :: View topic - 77 rear control arms
77sprint
Necoa #: 2207
Model: Sprint
PostPosted: Mon Feb 02, 2004 2:51 pm    Post subject: 77 rear control arms Reply with quote
Well, my 77 rear end feels like it jumps all over the place every time I cross RR tracks or hit a pot hole. I have new shocks and the only thing I can think of is that the bushings in the upper or lower control arms is shot.
Does anyone have any suggestions of other possible causes and/or has anyone replaced those bushings, how big a job is it replacing the bushings, and did it clear up mushy rear suspension in bumpy conditions?
Alabama Sprintman
"77 GMC Sprint (currently)
"73 Elky SS
"71 Elky
Tommy
Director Region 5
Director Region 5
PostPosted: Mon Feb 02, 2004 6:50 pm    Post subject: Reply with quote
They are not hard to change out if you have access to a hyd. press. I boxed my arms & added poly bushings. It made a huge difference in the the control & possitive feel of the rear.
CHVYPWR
Necoa #: 364
PostPosted: Mon Feb 02, 2004 7:31 pm    Post subject: Reply with quote
How much air are you running in the air shocks? If your close to 100psi, the rear will bounch like that.
77sprint
Necoa #: 2207
Model: Sprint
PostPosted: Mon Feb 02, 2004 8:01 pm    Post subject: Reply with quote
Gosh, I am running maybe 40psi, and when they are all the way down to 10psi it does the same thing.
I was reading some old threads that recommended not to get poly if you can get rubber. I have no idea myself. In fact, I'm not sure I can even find a choice of the two. Almost all parts you 5th gen folks can find, isn't usually available pre-78, in fact pre-82 to tell you the truth.
I guess I'll just take what I can get and be thankful for that... Sad
Alabama Sprintman
"73 Elky SS
"71 Elky
CHVYPWR
Necoa #: 364
PostPosted: Mon Feb 02, 2004 8:14 pm    Post subject: Reply with quote
New rubber just might do the trick then. On my '78. I got rid of the air shocks and went with KYB gas-a-just shocks, and BMR control arms with polyureth. bushings. The rear rides MUCH better than with the stock stuff with air shocks.
Tommy
Director Region 5
Director Region 5
PostPosted: Tue Feb 03, 2004 5:04 pm    Post subject: Reply with quote
Yes, Air shocks were never designed to give a good ride. I install kyb shocks & air lift bags & have never looked back. Huge difference in ride & handling. First change those bushings.
NASTYN8
Necoa #: 2328
PostPosted: Wed Feb 04, 2004 11:21 pm    Post subject: Reply with quote
summit racing sells full poly bushing sets for the 77 elcamino! its got suspension and body replacement bushings.. i think it runs like 160.00 or so..
"First impressions are always best......except against a sleeper!"
Tommy
Director Region 5
Director Region 5
PostPosted: Thu Feb 05, 2004 12:38 pm    Post subject: Reply with quote
You can order poly bushings from many of the auto parts stores. I got mine from a local speed shop.
Poncho Villa
Necoa #: 1849
PostPosted: Thu Feb 05, 2004 6:44 pm    Post subject: Reply with quote
NastyN8,
I think the kit to which you refer is Summit's ENS-3-18111G for $169.88. However, unlike similar kits for 3rd gen & 5th gen El Caminos, this kit doesn't include the body mount bushings. Mad
Like 77Sprint noted, it's hard to find some of these aftermarket parts for the 4th gen.
The search goes on...
Poncho Villa
1977 El Camino Classic
NASTYN8
Necoa #: 2328
PostPosted: Fri Feb 06, 2004 6:57 pm    Post subject: Reply with quote
Poncho Villa, you are right, my bad. After more research on the web i think i may have found away to get energy suspension to make body mounts for our elky's........ They just need a car to make the first ones, and whosever car they use will get a set of body mounts free....(99% sure on this stuff) call them and see what they cay. By the way energy suspeneion's "shop" is in cali Sad
77sprint
Necoa #: 2207
Model: Sprint
PostPosted: Wed Feb 11, 2004 2:37 pm    Post subject: Reply with quote
Well, I've got the poly bushings by energy suspension at a local speed shop. I am lucky enough to have access to an auto skills center at a local Army base. I went in to do the diry. The shop forman who kind of helps everyone out said the last 4 times he tried to press out the bushings, it calapsed the arm before the bushings moved and he would try again if I wanted to take the risk, well I figured I"d check with my buddies at NECOA and see what the skinny really is. The arms are indeed a "U" channel and without the special factory tools, calapsing the arms looks like a real possibility. And then how hard are the upper control arm bushings in the differential case to get out without the GM bushing puller?
Oh yeah, Cool I got my idiot light pod out and the new tach/gauges in. All I had to do was reorder the pins in that 18 pin connector, and put in a few new lines. So far,everything works except the ammeter (which I have not got the nerve up yet to connect up)... A pain, but was definately do'able...
Alabama Sprintman
"73 Elky SS
"71 Elky
77sprint
Necoa #: 2207
Model: Sprint
PostPosted: Wed Feb 11, 2004 2:42 pm    Post subject: Reply with quote
Oh Yeah, the local GM dealer here (the only one that still has the specialized tools) wants
$$$$$$ 430
LABOR
ONLY !!!!!!!!
to put in the new bushings
Yeah Right BUDDY Laugh
Alabama Sprintman
"73 Elky SS
"71 Elky
CHVYPWR
Necoa #: 364
PostPosted: Wed Feb 11, 2004 2:45 pm    Post subject: Reply with quote
A little info here: http://www.elcaminocentral.com/modules.php?name=Forums&file=viewtopic&t=401&highlight=bushings
Any ?'s on the torch and air hammer method, let me know.
77sprint
Necoa #: 2207
Model: Sprint
PostPosted: Wed Feb 11, 2004 3:05 pm    Post subject: Reply with quote
That shop forman I was talking about said someone else used a torch to burn out the old rubber and then a hack saw to cut the outter sleeve. Even so, pressing in the new ones could calapse the arm too wouldn't it? and I am not up on the use of an air hammer to get bushings out and then back in..
BTW, I just ordered a new set of lower rear control arms with sway bar from a guy on the internet. The lowers, I may be able to take down to a machine shop and have the bushings put in, but I must admit to being intimadated Crying with changing out the uppers. It seems that if I get too rough with them, I could break out the bushing hole in the rear end..
I'm starting to think the ride in the old elky is good enough to live with Embarassed
Alabama Sprintman
"73 Elky SS
"71 Elky
tonuch1
Necoa #: 2349
PostPosted: Wed Feb 11, 2004 4:13 pm    Post subject: Reply with quote
I AM REPLACING MY LOWER CONTROL ARM BUSHINGS AT THIS TIME AND I FOUND IF ONCE YOU HAVE REMOVED THE ARMS AND SOAK THEM WITH A RUST PENITRANT FOR AWILE THE SEEM TO POP OUT WITH A PRESS. I SET THEM IN THE PRESS AND UNDER A SMALL AMOUNT OF PRESSURE I HIT THE ARMS AROUND THE BUSHING WITH A HAMMER AND IT BROKE FREE. I DONT THINK THAT THERE IS A SURE FIRE WAY TO GET THE BUSHINGS IN AND OUT.
Page Generation: 0.385 Seconds
