Necoa #: 1689
Posted: Mon Feb 09, 2004 12:03 pm Post subject: why won't my brake light work when hd lights are on?
When I first noticed that my left brake light wasn't working it was nite time and my head lights were on. So the next day I changed the bulb, and thought that it was working just find, but when I turned the headlights on the brake light went out. The light will flash when I put the left blinker on, but If I use the right blinker then it goes out. It does work when the head lights are off.
Could the problem be a blown fuse?
or something more complicated that has to do with the light system and blickers? _________________ do you bleed blue bowties?
Necoa #: 183
Posted: Mon Feb 09, 2004 3:45 pm Post subject:
It sounds like you have a bad ground at the tail lights or a bad light socket. _________________ 83 choo choo ss pro touring black with a 350 & 17inch torque thrust ii wheels. 1975 kawasaki z1 900, 1976 kawi kz 900 ltd, 1952 Anglia 400 small block old skool pro street, 05 kawi z 1000 06 Gmc Canyon 4x4 off road
necoa member# 183
Posted: Mon Feb 09, 2004 5:07 pm Post subject:
What Choo choo said & make sure the bulb is making good contact. _________________ 78 Camino SS, 355,built 700r4,3.23
One other thing you may want to check is your light bulb. You can very easily install the bulb backwards in the socket. GM's light sockets in those years were not of the best quality and it's easy to install the bulbs with the side pins in the wrong slots. I have ran accross this many times in the past. Just a thought.....
