El Camino Central :: View topic - ordered my suspension stuff
Elky85
Necoa #: 499
PostPosted: Thu Apr 24, 2003 9:06 pm    Post subject: ordered my suspension stuff Reply with quote
well hopefully by next weekend i'm gonna have one smooth riding corner blasting el camino. After i got my F41 sway bar (which isnt installed yet) i went ahead and ordered the bushings/endlinks, as well as the edelbrock ias shocks, and the eibach pro-kit springs. i was figuring to get these to help smooth out the bumps on the roads. lately, its been giving a rough ride it didn't seem to when i first got it. hopefully this will help alot Happy
CHVYPWR
Necoa #: 364
PostPosted: Tue May 06, 2003 4:48 pm    Post subject: Reply with quote
Are you doing the bushings yourself? If so, are you buying new upper control arm shafts, or reusing the old ones?
PostPosted: Tue May 06, 2003 5:15 pm    Post subject: Reply with quote
There's really no reason to replace the upper control arm shaft. It's not a wear item. All it usually needs is just a few minutes on a wire wheel to clean it up before you install the new bushings. I've never replaced the shaft when I've re-bush the arms.
Mr. Green
CHVYPWR
Necoa #: 364
PostPosted: Tue May 06, 2003 7:45 pm    Post subject: Reply with quote
Mr. Green
I was asking 'cuase I was getting ready to do just that. I just finished up, and the came out just fine. Melting the rubber with a torch is the ticket Smile I was being told by someone here at work that is was less hassle to go with a new shaft.
PostPosted: Tue May 06, 2003 8:08 pm    Post subject: Reply with quote
The hassle is discovering you've put the shaft in backwards after you've pressed in both top bushings. Shocked
acauth1
Site Admin
Site Admin
Necoa #: 124
PostPosted: Tue May 06, 2003 9:06 pm    Post subject: Reply with quote
Normally, you wouldn't need to replace the shafts...however, I have work on a few cars where the owner drove around for years with completely worn out upper A frame bushings thus trashing the shafts.
acauth1
Site Admin
Site Admin
Necoa #: 124
PostPosted: Tue May 06, 2003 9:09 pm    Post subject: Reply with quote
By the way, burning the bushings out is stinky and messy with much dripping, flaming hot rubber. Easiest method to remove the old ones is an air hammer. Easiest to install is a press or a big socket and vise.
Elky85
Necoa #: 499
PostPosted: Tue May 06, 2003 11:16 pm    Post subject: Reply with quote
i didn't replace the upper control arm shaft.
I'm waiting a bit before i take pics because the springs are taking a bit to settle. It rides like a dream, and takes corners very well. The old shocks were worn, and the new ones go over bumps nice and smooth.
PostPosted: Wed May 07, 2003 8:43 am    Post subject: Reply with quote
I've made up a set of different diameter tubing spacers (1.75", 2.5", etc.) kind of like the spacers for a lower ball joint press. I use them with my big bench vise to R&R the upper and lower bushings.
I agree about burning the bushings out. Not only is it dangerous but a snoot-full of burning rubber fumes is not an enjoyable high.
Mr. Green
CHVYPWR
Necoa #: 364
PostPosted: Wed May 07, 2003 1:57 pm    Post subject: Reply with quote
Burning the bushings out wasn't all that bad. Plus, I did it at work, so I didn't stink out my own stuff Laugh
camino81
Necoa #: 1068
PostPosted: Tue Jun 10, 2003 2:48 pm    Post subject: Reply with quote
I agree with the air hammer to get them out, that what i used on mine made it pretty easy.
camino81
Page Generation: 0.396 Seconds
