El Camino Central :: View topic - Relocating AC Compressor on 4th Generation
daves77
Necoa #: 2080
PostPosted: Wed May 05, 2004 6:21 am    Post subject: Relocating AC Compressor on 4th Generation Reply with quote
I have a 77 Elky and one of my grips is the AC Compressor is on the drivers side. Don't ask me why GM put it over there. Seems like they spent a lot of money for no reason.
What I would like to do is relocate it to the passenger side. This seems simple enough. I need a condensor with passenger side fittings, shorter hoses and brackets.
Any thoughts, ideas, suggestions, or I did its.
Thanks for any help.
Dave
ElkyPete
4th Gen Group Moderator
Necoa #: 3
Year: 1976
PostPosted: Wed May 05, 2004 9:45 am    Post subject: Reply with quote
I've just finished putting a Serpentine system on my 76 that is about the only reliable way to re-locate the GM style compressor. A Condenser from a late 80's Camaro should suffice for that part then you need to do something with the combination Dryer/Accumulator /orifice. I got a accumulator for an 80 Elky it fit on the evaporator fine. The other hurdle is making a hose for the high-pressure side with an orifice tube. I ordered one from an auto parts store, generic orifice tube. I am making a line for the high side. AeroQuip now makes some fittings and braded hose that is designed for AC applications and allows you to do your own work. It even looks nice.
The other option is to purchase a whole setup from March or Zoops that have the compressor mount on the passenger side. Then you will still have to make hoses and get a sandon compressor, which is actually better than a stock GM compressor, keeps working up to 9000 RPM, and uses less energy off the engine to turn.
So there are two good ways to go. My serpentine system came off a 91 Chevy Pickup. If you go that route get the whole sa'-bang don't leave anything behind. The fan will rotate different and the water pump is rotating opposite, the Alternator is smaller and is a one wire set up not like the one that you now have plus its all using a different belt so nothing you have now will fit. Nothing! Either method.
Now that its all done and working I like it a lot better and I got rid of a vibration issue when that happened that I didn't realize was a result of the aftermarket pulleys I had installed (Polished Aluminum)
daves77
Necoa #: 2080
PostPosted: Wed May 05, 2004 8:44 pm    Post subject: Reply with quote
I am hoping to keep the long Harrison compressor. I believe (but not sure) some of the older Chevys had the compressor on the passenger side. A friend of mine mentioned he thought Buicks had the compressor on the passenger side.
I am removing the newer center bolt engine (previous owner installed) and rebuilding an old style 4 bolt main engine this week. Next mod will be changing the trans from auto to manual.
Dave
PostPosted: Wed May 05, 2004 11:39 pm    Post subject: Reply with quote
Pontiac's have them on the passenger side too. AT least the 69 firebird's do as well as the GTO's I believe. Very Happy
Nailhead
Gold Contributor
Gold Contributor
Necoa #: 1579
PostPosted: Wed May 12, 2004 7:12 pm    Post subject: Reply with quote
Some Buicks and Pontiacs did indeed have the compressors on the passenger side, but I don't think any of these brackets are going to bolt up to a small block (or big block) Chevy.
bsg208
Necoa #: 302
PostPosted: Sat May 15, 2004 2:46 pm    Post subject: Reply with quote
I have the serpetine belt on my elkie and I used the High pressure hose assy for a 1987 Caprice. It fits great. I also used the condensor from the 87 Caprice.
Mrapii
Necoa #: 2314
PostPosted: Mon May 31, 2004 3:57 pm    Post subject: Reply with quote
UH....I'm missing something here. Is there any reason why having the AC compressor or the right side of the engine is preferable to the left?
SirVette
Necoa #: 1507
PostPosted: Fri Oct 01, 2004 9:01 am    Post subject: Reply with quote
Corvettes have it on the right side- ideal since the evap. is on the right side. It could be set up like a Corvette w/ the lines running from the compressor forward to the condensor & back to the evap. w/o lines across the engine. A very clean setup. Have a Sanden type setup on the Corvette.
Cool
Older full size Chevys have it on the right side.
The Corvettes use a short water pump, so a spacer would be needed.
Corvette Stingray 383
vrooom3440
Necoa #: 3296
PostPosted: Fri Oct 01, 2004 8:42 pm    Post subject: Re: Relocating AC Compressor on 4th Generation Reply with quote
Dave
From a purely bracket perspective I recommend checking out:
Alan Grove Components
They might not be sexy but they have about the most diverse collection of brackets I've seen.
As to the other stuff... sounds like mostly a matter of making the right lines up.
I am putting A/C on a '68 and putting the Alt on DS and A/C on PS. Along with power steering, BB, and long water pump I did not see many brackets to get me there. But Grove has exactly what I needed as well as some really weird specialized stuff.
Steve
