Necoa #: 1419
Posted: Wed Jun 02, 2004 12:33 am Post subject:
Should fit with no problem...if the off-set is correct and the tire size is correct. Remember even though you have 14's your tire is taller. You can run 16's even 18's with a lower profile tire. The total wheel and tire can come out to the same size as your 14's combo. _________________ 70 ElCO
