So I took apart my dash to change out the bulbs and paint the interior to brighten up the gauges about 2 weeks ago. Today I'm driving home and notice a burning smell. When I got home I started looking around and saw a tiny bit of smoke at the headlight switch. Turned the lights off and pulled the front of the gauge cluster to check things out and the headlight switch was real hot. Not burn me hot, but much too hot for something inside the car. I pulled the switch out and I can see a little discoloration on the ceramic part by the dimmer coil. Put it back together to see what part is getting hot and now none of the lights in the gauge cluster turn on. The dummy lights work fine and so do the stereo and washer lights. They turn on, dim and turn off with the switch, but I have nothing for the gauge illumination bulbs.
My first thought is that I burned something up inside the switch due to the extra voltage draw with the 2825 bulbs (5 candlepower vs. 3 candlepower). But the other lights work just fine. Now I'm wondering if I burnt something up between that switch and the gauge panel. Anyone had this problem? Or at least give me a good idea of what parts to check out next before I pull the whole cluster and run through the wires?
